Question about Sharp Office Equipment & Supplies
I stopped using my sharp AR 5020 after i closed down my business cafe 5years ago, now I have a school i want to keep using it but can't remember the pass codes. I need help to reset the code
  • 4 Answers
SOURCE: RESET V CHIP PASSWORD ON SHARP 13 INCH TV 13L-M100B
Downlaod the Operation Manual here
http://www.sharpusa.com/files/tel_man_27C240.pdf
Posted on Feb 10, 2008
  • 62 Answers
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Posted on Mar 23, 2008
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
mickspaceNET
  • 115 Answers
SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Posted on Feb 06, 2009
  • 990 Answers
SOURCE: sharp AR-R550n
Hello sir; You may try to perform a reset procedure as follow;
press " program", " * ", " clear ", " * " and start key, then enter 17, press start again, turn machine off and back on.
Posted on Aug 23, 2009
HOW TO FIX H4 ON SHARP AR 5020
Enter sim 14 if not help check thermostat in the fusing unit
Jul 06, 2014 | Sharp AR-5320 Black and White Copier
Sharp AR 5020 simulation
C - interrupt - 0 - interrupt
Jun 19, 2014 | Sharp AR-164 Copier
Getting u 2 error with my sharp AR-5020 please help
U2 - EEPROM read/write error (serial communication
error)
Mar 05, 2011 | Sharp AR-5320 Black and White Copier
My Sharp copier AR 5316 does not work with Vista business service pack-1. It does not work when print option given for current page and printer sleeps and does not take the printing order. One has to...
have you installed the PROPER Vista driver? Or just used the install disk that may have come with your machine years ago, and may not be designed for "Vista". Go to sharp and download the proper driver, or at least see if it is supported.
Feb 01, 2010 | Sharp AR-5316 Advanced Digital Imager...
I am using Sharp AR-5316E copier (It makes noise)
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Jan 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR 5020 error F5-02
you reset your eror code program c#0#
May 30, 2009 | Sharp AR-5320 Black and White Copier
SHARP AR5320 error F5-02
SHARP AR 5020 error F5-02 pls canu give some tips very helpful its urgent sir
Dec 15, 2008 | Sharp AR-5320 Black and White Copier
Error: Printing data is inaccurate, printing processing is stopped Printer error page is printed with this error prints fine from the webpage printer is installed on windows 2000 over a network
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
Aug 22, 2008 | Sharp AR-M207 All-In-One Laser Printer
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
