Question about Exercise & Fitness
Looking for the display screen vitamaster 850 treadmill
Manual for a 88c vitamaster stationary bike
See instructions for setup at the attached link, it is the best I could find, no actual manual was available for download. Instructions on Vitamaster Exercise Bike
Sep 07, 2016 | Exercise & Fitness
Where can I find parts for my vitamaster 2 treadmill
Go to this link,
Jul 01, 2015 | Exercise & Fitness
Can not calibrate a true 850 ztx treadmill. has error code E5:sensor. aborts calibration saying no speed sensor. is the speed sensor located within the main motor? What lights should be seen on the...
However reset the treadmill
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 24, 2013 | True 850 ZTX-P Treadmill - Serviced
My lifestyler expanse 850 control panel has stopped working but the belt still works?
1( adjust the REED switch, see the diagram, clean it, and tight the wires connectors very well.
2) replace the batteries.
3) clean the contacts batteries with special cleaner
4) retight the spring contacts batteries for better contacts.
5) tight the ribbon cables from keypadys vs display board.
6) tight the display board connectors vs lower board.
Jul 10, 2012 | Treadmill Doctor Lifestyler Expanse 850...
Need rear roller for vitamaster treadmill #9866 part# 36-9004T
Dear Sir:
Please go to : www. + + www.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 07, 2012 | Exercise & Fitness
Please help find the manual for this Roadmaster Vitamaster 9890 Treadmill
I will give 2 options:
1) is free:
2) is Not free:
I hope with this is o.k
Oct 22, 2011 | Exercise & Fitness
Looking for lubrication points for my Vitamaster Pro Treadmill
home depo sells dry lubricants it is yellow spray can
first clean it wit W40 and spray the lube your treadmill feels better
wish the best
Nov 18, 2010 | Exercise & Fitness
Walking belt for vitamaster 700
ultrafitness we got belts cheep 4 every make and model
Jan 27, 2010 | Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
