Question about Bosch Computers & Internet
Bosch is coppy and I loose the sound. Netflix nor yuotube has this problem
How do I get volume for my apps( Netflix,etc) picture good, no volume
Are on Windows 8 or an older OS. With Windows 8 Silverlight probably has it own volume control. Silverlight is the API used by Netflix to access you systems audio and video devices. If YouTube is OK (since it uses Flash and not Silverlight) then you have isolated the problem to it being Silverlight. However, this assumes the sound work normally for all applications and the OS. Of course, I once had a loose speaker wire on my center channel and some show were missing dialogue depending on how they were mixed so anything is possible but you never mentioned anything else being a problem.
Sep 21, 2014 | Microsoft Xbox 360 Console
Sound choppy
HI, how does it game?
Can you play games on the system for more than "10 min" without issue? I ask, because gaming should cause more issues with overheating than watching Netflix.
Dec 02, 2013 | Nintendo Wii Video Game Consoles & Games
My Bosch Nexxt 100 washer is making a clanking noise. I checked to see if anything was in the pockets of the clothes I was washing. It sounds like something is loose inside of the washer but not in the...
By your description of the noise<it sounds as if the bearing in the "agitator"is defective or "wornout". Or at times anymetal object could some out of pockets and get lodged under the drum of the agitator.you can check this by taking a long flat object,such as a rule,and slide it around the inside of the the machine.
Feb 12, 2011 | Bosch Washing Machines
Hi ive a 18v bosch striker cordless drill seems to stop when heldon left side sometimes goes better when i tape the lithium batery to stop looseness can you help is it triger , brushes , or loose...
Well it sounds like you solved it yourself. The contact springs may have loosened just enough to reduce the battery connection to an intermittent state.
With needlenose pliers, see if you can gently squeeze the receiving contacts back together so when the battery registers with them they hold it firm.
Good diagnosis
Mike
Nov 20, 2010 | Bosch Drills
Early in the wash cycle, my Bosch diswasher makes a chirping soun
yes the problem from the heater.
if the sound coming from boiler heater means
1)scaling on the boiler tank(tank to be cleaned).
2)check any loose connection on the heater wire.
Jan 09, 2010 | Bosch Dishwashers
Coppying speed is slow
in vista you need to change the remote differential compression.  Can be found in control panel?programs?windows settings I believe.  Turn it off.  As far as XP, sounds like a problem with the hard drive or memory.  I know of this issue in vista, but never ran into it with XP.
Mar 06, 2009 | Computers & Internet
Bosch dryer
try lifting the drum from inside to check for any excess lift. it may be a bearing or bearing bracket.
Feb 16, 2008 | Bosch WTMC1301US Electric Dryer
Computers & Internet Logo
23 people viewed this question
Top Bosch Computers & Internet Experts
RudeRude
ray gallant
Brett Duxbury
Brett Duxbury
Are you a Bosch Computer and Internet Expert? Answer questions, earn points and help others
