Question about Fisher and Paykel Ovens
I have a Fisher and Paykel pyroletic wall oven. I have removed all trays and shelves. It says to remove the side racks but they look like they are in permanently. Do I have to remove them?
    Sergeant:
  • Fisher and P... Expert
  • 499 Answers
That depens on you if cleaning it no you dont have but you may not be able to remove the fan cover for cleaning
Posted on Jun 01, 2018
  • 417 Answers
SOURCE: wall oven on automatic with 0.00 flashing and will not go
You need to set the clock to the correct time and this should take it out of automatic mode, it should then work o.k
Posted on Nov 30, 2008
  • 523 Answers
SOURCE: Removed racks and rack support from my Electrolux
turn off power the back on
Posted on May 27, 2010
tbirdfan1
  • 3051 Answers
SOURCE: F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: After self cleaning the racks no longer fit
Seems like you found out the hard way what I wrote about in this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Aug 14, 2010
KevinWhite
  • 1902 Answers
SOURCE: Fisher & Paykel double wall
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Feb 03, 2011
How do I get the lubrication called white grease back in my oven racks on Fisher & Paykel oB30 model? There were left in the oven during self clean months ago. Thank you.
You can use a mixture of 1/2 cup white vinegar, 1/2 cup baking soda, 3 cups water. Mix all the ingredients together and coat the entire inside of your oven with it. After 5 min scrub the mixture off and wipe clean with a damp cloth. Don't forget to clean the heating element at the top. That helps with cleaning the racks or discoloration. You can try scrubbing the mixture with a toothbrush into discolored areas.
White lithium has a drip temperature of 190 to 220 °C (370 to 430 °F). It is a lubricant used on hinges. It adheres strongly to metal, resists water, is non-corrosive, and resists heat. If from a spray can, the propellant smells strongly and is highly flameable and definitely is not something you want to breathe. Definitely air out the area.
It can be acquired from Ace Hardware. Home Depot, or Amazon, among many other sources. It is sometimes referred to as Lithium soap.
Jun 12, 2017 | Fisher Ovens
Fisher Paykel OD302 double wall oven. Exhaust fan assembly (vent fan) wiring.
get an electrician in to fix it
the red wire is normally the active (power wire) and the blue is the neutral wire
if you fit the blue to a red terminal then you could be dead, blow the circuit or blow a circuit breaker
be safe call an electrician
Dec 05, 2016 | Fisher and Paykel Ovens
Hi, the two cooktop elements on the left of my Fisher and Paykel in-cabinet oven with ceramic cooktop do not turn on. The switch light doesn't turn on, but the right side elements work.
normally there is a live wire for right and one for the left this maybe off,turn off at wall and remove the back to see any wires that maybe off
Nov 05, 2016 | Fisher and Paykel Ovens
How do I replace the fan in a Fisher & Paykel 60cm oven
ill assume your referring to the cooking fan you see inside the oven and not the outer cooling fan, you will need to turn the breaker off outside to cut power to the oven then you will have to take the oven out of the wall and remove the back cover then its normally just 3 screws and the nut on the inside of the oven that holds the fan blade on (which is reverse threaded by the way) and it should come out
Sep 27, 2014 | Fisher and Paykel Ovens
When changing seal on Fisher and Paykel oven is it OK to turn oven off at wall before removing back panel ?
Yes it is suggested as well to shut off the electrical breaker that provides power going to the oven. If you have any further questions message me back Thanks Rick
Jul 05, 2011 | Ovens
hELLO THERE:
Jul 14, 2010 | Fisher and Paykel Ovens
Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Nov 01, 2008 | Electrolux ICON Designer E30SO75ESS Oven
Ovens Logo
121 people viewed this question
Top Fisher and Paykel Ovens Experts
Joseph Hoffmann
Oloyede Monsuru
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
