Question about Refrigerators
My ice magic plus is not getting water to make tj
huuum
  • 750 Answers
SOURCE: Griding sound in Ice Magic Plus box in freezer compartment.
Hello garydeanr,
Welcome to fixya.
You said,, There is a constant grinding sound in the Ice Magic Plus compartment in the freezer compartment. The ice maker is making ice.
What is your exact model number and How Old is your fridge?
I'll be able to run it through the repair system and check for you!
Waiting your response!
I believe that,
From here this sounds like one of many normal sounds. is a normal sound.
You can go to this site and scroll to page 9 where it will tell you all the normal sounds your fridge can make.
I tried to cut and past it here for you, but it is not copyable from the site!
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202220699.pdf
I think you can rest assure that it's okay.
Huuum ,
Please remember to leave a rating!
Posted on Oct 21, 2008
jdforero
SOURCE: I have a whirlpool Magic plus ice maker that is
You should disconnect the refrigerator and wait until all the ice melt. Better if you open the door of your freezer. Not need to open the door of the refrigerator. Then connect it again and the device wil start working
The other way is to take off the cover of the ice maker and clean all the ice that can be obstructing the device to return to his inicial position that release the entry of the water.
Posted on May 08, 2009
  • 93 Answers
SOURCE: I have a whirlpool side
yes it sounds like the unit is not defrosting. u might need to check defrost timer and then u might even have to change out your defrost heaters and termnation switch. try that ok. lkater gator.
Posted on Feb 16, 2011
imufo2
  • 3773 Answers
SOURCE: Ice Magic Plus not making
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 24, 2011
  • 12962 Answers
SOURCE: im getting water to the door of my fridge but not to my ice magic plus. how can i fix this?
Check out the solenoid that feeds water to your ice maker for proper operation.
Posted on Apr 18, 2017
Im getting water to the door of my fridge but not to my ice magic plus. how can i fix this?
Apr 18, 2017 | Refrigerators
IC MAKER WORKS BUT NO WATER OUT OF WATER DISPENSER?
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
I have a whirlpool side by side with water/ ice magic plus my freezer is producing ice on the walls and top of freezer. my ice maker is making a noisewhen i close the freezer door (my seal on the ice...
Feb 15, 2011 | Refrigerators
I have a model SS6SHAXMB00 side by side Refrigerator Freezer. My problem is the Ice Storage Container freezes into a solid chunk of ice. We don't use a lot of ice and like to take it by hand from the...
Water may be dripping into the ice bin. If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Also the water can be diverted from the ice mold by ice blocking the fill tube if the water inlet valve is leaking.
Sep 21, 2009 | Refrigerators
Low water flow from "ice magic plus"
Have you tried replacing the inline filter? and if you have remove the filter and place a large bowel next to the water line and open it up and see if water flows from the line, if it flows fast then it's a problem with the fridge if it folws slow you have a problem with the water connection. Check that can get back to me if you need more help.
Avid101
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool Magic plus ice maker that is not working. The water doesn't not fill tray. No ice.
Apr 12, 2009 | Kenmore 21.7 cu. ft. Side-by-Side...
Not making ice.
EITHER YOUR ICEMAKER IS BAD(IS THERE WATER IN THEWELL AREA?)OR YOUR 2 WAY WATER VALVE ON THE BACK BOTTOM OF FRIG. IS BAD(ONLY ONR=E SIDE WORKING,LET ME KNOW WHAT YOU FIND-MIKE
Jan 13, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Whirlpool Ice Magic Plus not make ice at all.
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out(beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Jan 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hello garydeanr,
Welcome to fixya.
I believe that,
Huuum ,
Oct 21, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Aug 25, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
