Question about Car Audio & Video
I cannot obtain a defond CYM-1213-A switch for my Toro leaf blower. i want to install a comparable variable-speed rotary switch--13A, 125VAC. any way to jerry-rig a suitable replacement?
There are 4 terminals/ leads on the old switch [one doubled up black] with 3 wires [black, purple, blue]connecting to a CHN 418 transistor or resistor [sorry, I'm not an electronics whiz]. is the resistor absolutely necessary?
  • 52 Answers
SOURCE: hampton bay ceiling fan
This should do the trick. Good luck and make sure the power is off.
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
Posted on Jan 29, 2008
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
we have a hampton bay fan burning smell coming in didnot run
Posted on Jul 07, 2008
  • 351 Answers
SOURCE: Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
Posted on May 25, 2010
Testimonial: "I appreciate the response, which reinforced my thought process and it worked - Thanks!"
SOURCE: I have gotten a replacement
If you have these colors the locations are:
L Black
1 Gray
2 Brown
3 Green
Posted on Oct 01, 2010
I need a part CYM-1213-A for my Toro electric leaf blower/vac. Where can a get one? Thanks, Mike
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 11, 2017 | Toro Garden
Looking for defond cym-1213-a
look on the internet
Oct 29, 2016 | Watches
Who sells a Defond CYCM-1213-A rotary switch for a Toro Garden Blower/ Vacuum
Ebay has listing for Defond switches. Don't know if they carry that specific model number.
May 29, 2015 | Toro Garden
What is a Defond-2113?
Defond is a manufacturer of the Switch
Nov 15, 2014 | Garden
Where can I buy a Defond CPU-2113 safety switch for a Toro Blower/Vacuum?
If you do not use the Blower / Vac for Vac you can cut out the the reset switch, it's only when you get foreign material in the impeller using the Vac stopping the motor, I cut out the switch. As you look at the Defond switch (side with writing you see a white wire and a black wire side by side. mark the black wire with a small piece of tape 1-1/2 inches from the connecting lug. Cut all wires off the switch. Strip wires back 3/8 to 1/2 inches. Use heat shrink tubing
and slide it back on the black wire with the tape, same thing thing with the black wires on opposite side of the switch. Use a end to end splice as opposed to a parallel splice because of wire routing space..Splice the white wire with the black with tape, Then the other two black wires. using heat shrink tubing to cover the splice. Good idea to take a picture (smart phone) so as to see wire routing after you separate blower halves, very little wire routing space. Make sure motor is seated in it's nest before joining halves together do not use Vac if you use this fix. Mine works just fine, save $60+ bucks.
Nov 01, 2014 | Toro Garden
Toro blower-vaccuum stop working
Replace the variable speed control with a toggle switch. Cut the 2 power wires that go to the big rotary knob and wire to a toggle switch that you can install by drilling a hole near where the power cable enters. Works great and full power all the time.
May 25, 2014 | Toro Electric Ultra Blower/Vac 12 Amp
My Toro Ultra 12 amp Variable-Speed Electric Blower is losing power
Make sure the electris moter is free of and debree like leafs or grass if that dont work the next step is the winding in the motor you could get the motor re-spun or just go out and buy a new one might be cheaper.
Mar 25, 2012 | Toro Garden
Stopped abruptly won't restart
tThe flywheel is indexed to the crankshaft with a soft aluminum "shear" key, when the blade is stopped suddenly the key is broken instead of the crankshaft. The flywheel will need to be removed and a new key installed. Make sure to clean the shaft and flywheel mating surfaces so they fit tightly or the new key won't last too long.
May 27, 2010 | Toro Lawn Mower With Toro Power Tools
Car Audio & Video Logo
278 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
