I bought my son a chainsaw for xmas in 2015.Took it to a authorized service center in Oct 2016 they repaired it. But now Poulan wont pay them they wont give the saw back. I think the bill is like 300
Idle ports may be plugged or blocked - This is the small ports in the carburetor where the fuel passes through when in idle. ... Vent in the Fuel Cap is plugged - If the vents in the fuel caps are clogged the fuel becomes vacuum locked. ... Starting with the High Speed screw, turn it ...
? 1:32
https://www.youtube.com/watch?v=aIUVQziXBPY
Jul 7, 2011 - Uploaded by BriggsRepair
Is this Craftsman 16" chainsaw broken? Hardly. Watch this carburetor fix and how it runs brand new!
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 14, 2011 - 10 posts - ‎7 authors
I have a Stihl MS 180C that i cannot get to run. I used it all last year and went to use it a few months ago and it didnt seem ... it is not under warranty and i have pulled and pulled with choke on and throttle wide open and still wont start. ... Depending on the carb, some times you can just go for broke and get a ...
Stihl ms 180 running rich
Jun 5, 2015 Echo cs-370, they actually work
Oct 12, 2010 More results from www.arboristsite.com
Poulan has had a notorious carb issue over the past couple of years. Products roll off the line needing a carb adjustment right out of the box. One adjustment is covered under the warranty at a service dealer near you. Look up your closest dealer at poulan.com. This is not something consumer serviceable as it requires a special tool.
it's an 18 " poulan bar and chain...just a standard bar and chain for poulan...most of the aftermarket brands have a cross reference that will give you an idea on which to use
1.Try to understand,without waranty not able to service your laptop without charge.
2.I thing you are not statisfing with acer service
3.In this scenario you go to consumer court with strong proof.(that means how many days of your laptop stay in service center only like that)
Should still be warranted. Why void the warranty? Take it back or find an authorized service center. Poulan.com http://www.poulanpro.com/node4042.aspx The site says 1 year warranty. HTH Lou
