Question about Memorex Radio Communications
My memorex wireless headphones will not charge I have no red light I can get them to work with my blue tooth when plugged up but as soon as I unplug from charger it stops working.It a MHBT0245BK
SOURCE: logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Posted on Mar 19, 2008
farhangM
  • 64 Answers
SOURCE: Gateway Laptop not charging
It sounds like defective power jack. Bring it to a reapir shop.
Posted on Dec 01, 2008
SOURCE: Built-in speaker in Mac doesn't work (red light!)
I took a safety pin and put it in the notch inside the headphone jack input. notch is located at 12 o'clock about 1/8th inch in, (this is an important step, other steps are no good until red light is off) the red light went off (Be patient this step may take time) still no sound, I then went to Audio MIDI setup (Should be located in Applications/Utilities), go to Audio in menu bar (at very top of computer screen) and selected 'open Aggregate Device Editor,' clicked on the + to add a device I then had a few options show up in the lower [Structure] portion I clicked on all the 'Use' boxes and the built-in output bubble selected done. I then Selected Configure Speakers in Audio MIDI setup and I can test my left and right speakers individually, they put out a fuzzy test sound, pressed done when finished. They still didn't work so I set Default out put to the Aggregate Device I created, then turned on Itunes and it was working fine I just could not control the volume from the F3, F4, & F5 buttons so I went to sound in system preferences and made sure the built-in Output option was selected. I was then able to control the volume. The red light in headphone jack input may come back on if anything is inserted inside, just mess around with the notches inside till it goes off. Hope it works as well as it did for me. Good luck and please feel free to quote me and share this solution with others.
Posted on Jan 22, 2009
SOURCE: logitech freepulse headphones not charging?
Same Problem, Headphones will charge but they wont turn on no matter what you do. Called, got them replaced, so I thought hmmm I can figure out what went wrong with the old ones.
It is the switch itself. The connection next to the charging plug does not make contact anymore. It is a weak point and after putting excessive force on the power button it actually twists the switch enough to beak the solder joint. DO NOT LIFT THE SWITCH ITSELF! Just solder the one next to the charging plug and it will be good to go.
To take them apart is a pain. Remove foam by pulling on it. Remove tiny torrx screw (CR VT-6, bit I used), then remove (actually pry up) silver "ring" at the point where the band meets the ear piece. Finally, pry apart at the band section. I used a razor blade. It is 4 tabs on the inside and is a pain, but came apart. Then take 2 screws out to remove the band and there is the board.
Solder the switch next to the light and charge plug and it is good to go.
Hope this works,
Ryan R. Gerner
Posted on Feb 28, 2009
  • 973 Answers
SOURCE: My Vector Vec157 Flashlight won't Charge...
It is the battery, I have a similiar Vector light for a few years and tried re-charging the battery but only the little LED light would come on. I have another Vector light, same model and switched batteries from the worjking one to the non-working one and now it works fine.
I then proceeded to purchase a new battery for the non'working one and when I arrived home I installed it and turned on the main light, still won't turn on, I tried the LED's, they work. I figured maybe the new battery needs a good charge so I plugged the charger in and charged the light for 12 hours, still no main light.
I guess the new battery is defective, so now I will return it and exchange it for another one.
Posted on May 27, 2010
My p.c does not get any drivers for my sansui bluetooth headphones.
If you have other blue tooth devices working correctly, do a search for new devices on your blue tooth software. Pair the headphones using the blue tooth software.
Jul 15, 2015 | Audio Players & Recorders
Plantronics audio 995H wireless headset not charging when plugged into computer. It does not show a red light for charging. When turned on it stays blue for several seconds then flickers red for 2 or
38cafd7a-6060-4717-bc4f-b4db91cc266a.jpgI recently fixed my 955 headphones... it's probably not going to be attempted by most folks, but it saved a great set of headphones from being tossed and replaced.
Basically you need to remove the right side padding and take out the 3 screws. This gets you access to the battery. The battery is a standard 3.6V lithium battery. Pretty much the same that is in most cell phones and many small toys. You can simply replace the battery with something like:
http://dx.com/s/3.7v+li
Or... here's what I did... add a lithium USB charger to the battery.
http://dx.com/s/li+arduino
Now, if the battery dies I can plug it into USB and the phone will work while it charges.
Nov 12, 2013 | Plantronics .Audio 995 Digital Wireless...
My sms audio by 50 cent wireless dongle stopped working after putting it for charging
When I plug in my dongle to charge the blue led light comes on but when I want to use it, it won't turn on??
Mar 08, 2013 | SMS Audio SYNC by 50 Wireless Headphones...
Cellular Innovations HFBLU-FP1 T2 FP1 wont charge
bluetooth - charging mashine problem bring it to recheck the charger
Apr 15, 2012 | Cellular Innovations HFBLU-CX1 Wireless...
I go to charge my back beat 903 and all i get is a red blinking light and they want power up.
Here's what Plantronics tech support had me do to fix this problem:
Step 1:
Push and hold the on/off button and without letting go insert the charger and you will see a steady light on the headset
Step 2:
Let go of the button as soon as you see a steady light on the headset
Step 3: Unplug the charger from the headset, Reset should be done by now and you will be able to turn them on again.
After Step 3 I plugged it in again (I probably could have simple skipped step 3 altogether), because my headphones were completely dead and needed to charge for 3 hours before they were ready to use again.
Aug 11, 2010 | Altec Lansing BackBeat 903 Consumer...
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Radio Communications Logo
83 people viewed this question
Top Memorex Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Memorex Radio Communication Expert? Answer questions, earn points and help others
