Question about Mastercool Heating & Cooling
Why is my mastercool evaporative cooler making a rythmic knocking noise?
SOURCE: noise on mastercool
had the same symptoms and found that tightening the squirrel cage set screws eliminated the noise.
Posted on Jul 01, 2008
SOURCE: AC pad not fully getting saturated with water
1. Make sure the pump is getting plenty of water.
2. Make sure the pump is working.
3. Check the pvc pipe with drip holes are not plug. (above the pads )
4. Check the pads directional arrow that should be facing up. When pads are initially installed you can see arrows on the pads. The arrows should be in the up direction. That will allow the pads to get saturated more efficiently.
I hope these steps help you.
Jerry,
Posted on May 08, 2009
Ed Phillips
  • 11 Answers
SOURCE: New Mastercool pads smell bad
The cellulose pads in a mastercool are glued together and usually the adhesive is what you smell. It may take a while for it to go away. Strange as it may seem, as the pads get more mineralization and you use it more the smell will go away. Do not use a cooler for your whole house without plenty of exhaust through a window or an updux. Coolers work best when there is plenty of freely moving air.
Posted on May 31, 2009
Ed Phillips
  • 11 Answers
SOURCE: loud rumbling noise in mastercool a/c
This type of cooler has "pillow bearings" where the squirrel cage fan rests in the frame. They must be lubricated with oil at least yearly. If they go dry the bearings can wear out and cause the noise. Oil them first to see if the noise is less and maybe you can get by without replacing them. If the noise is still there you may need a bearing replacement. Always turn off the power to the unit before you work on it.
Posted on Jun 20, 2009
  • 6 Answers
SOURCE: I need a wiring diagram for a mastercool
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Posted on Feb 14, 2010
The evaporative comes on but just idles and won't speed up making a noise and not blowing
Have you tried cleaning it? Because when mine wasn't doing what it was supposed to be doing i gave it a quick clean.
Jan 17, 2014 | Mastercool 67680 Evaporative Cooler Air...
Do they make some kind of transition for the side discharge MasterCool MasterCool Evaporative Cooler, ASA71 So when I cut open the side of my house I have a way to vent it thur the wall. Is there a kit...
Best way is to get a sheetmetal shop inyour area to make one for you.. Give them the exact size of the opening and then tell them you want a 3/4" flange all the way around and make sure the duct connection is what you need.. Let us know if you need anything else.. please vote.
Sep 05, 2010 | Mastercool 67680 Evaporative Cooler Air...
I need a wiring diagram for a mastercool evaporative cooler
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
My husband wants to install a mastercool evaporative cooler in a building that is completely open on one side. We live in AZ.
It will work fine as a spot cooler if he has direct airflow on him, otherwise it wont do much for cooling the building.
Jun 30, 2009 | Mastercool 67680 Evaporative Cooler Air...
Loud rumbling noise in mastercool a/c
could be the fan is full off dust or something causing it to be out of balance
May 19, 2009 | Mastercool 67471 Evaporative Cooler Air...
Vibration noise
unbalanced mounting or unbalanced fan. check how it stands and make adjustments.
May 12, 2009 | Mastercool 67680 Evaporative Cooler Air...
Noise on mastercool
May 23, 2008 | Mastercool 67680 Evaporative Cooler Air...
Heating & Cooling Logo
107 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
