Question about Sewing Machines
My sewing machine wheel will not turn lugging the motor down it is locked how to fix
  • Sewing Machines Master
  • 12,267 Answers
If your machine is an older mechanical, it is most likely bogged down from old, dry oil. If this is the case, continued attempts to run the machine may damage the motor.
Take it for service or
Wheel on right side that controls the needle up and down is very tight...
Posted on Apr 18, 2017
  • 19 Answers
SOURCE: Bernette 800D seized up
Please don't use WD40 on your sewing machine, WD40 is an alcohol based cleaner and will do the opposite of lubricate. Take your machine to a certified Bernina Repair shop, they will have a look at the timing and lubricate all of your gears. Lubricant will dry out over time, grease turns to putty and oils turn to varnish after several years of non-service. Lint is attracted to moisture, moisture being those key areas of any machine. Lint acts like an oil wick and will draw out your lubricant from key areas. It then begins to attract dust and other nasty things over the years to become grit. Your motor begins to burn out due to stress trying to move all of these clocked gears, cams and shafts. Take your machine in!
Posted on Dec 10, 2008
  • 980 Answers
SOURCE: hand wheel loose
In the middle of the stop motion screw wheel there is a screw, undo the screw and unscrew the stop motion wheel all the way off, you will now see a three pronged washer, take it off and put it in a different position, put the stop motion wheel back on and just tighten finger tight, tighten the small screw all the way, now loosen the stop motion wheel and press on the foot control gently, the balance wheel should move with moving the machine, if the machine turns then start over again, you can put the three pronged washer upside down if you wish.
Posted on May 13, 2009
  • 25 Answers
SOURCE: sewing machine jammed wheel will not turn
Thread is caught in the hook...Remove the upper thread and bobbin case...turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
Posted on Jun 02, 2009
  • 96 Answers
SOURCE: Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Posted on Dec 13, 2009
  • 371 Answers
SOURCE: My model 120 Husqvarna Viking sewing machine will
Repair manuals are available only to Husqvarna Viking authorized dealers. However, I have seen some on ebay from time to time. Sounds like your problem could be several things - binding of the internal drive shaft which may have a build up of grease and lint which unbinds as you sew, could be a faulty motor, or faulty transformer. Suggest that it be serviced and cleaned by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
Why doesn't it sew?
Check to see if the bobbin case is in correctly. Jamming occurs when something isn't in machine properly. Try taking out the needle & manually turning the hand wheel slowly. It could be just a bent needle too.
Mar 13, 2016 | Baby Lock Sewing Machines
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Sorry the needle is not going down,
Needles will not go down for:
1. The lock on the hand wheel isn't locking. Try this
a. Loosen the lock like you're going to wind a bobbin.
b. Loosen screw that is on the side of the lock. (sometimes front)
c. Tighten the lock just like when you're going to sew.
d. Tighten the screw that is on the side of the lock.(sometimes front)
e. Turn hand wheel by hand. Did the needle rise and fall?
2. The drive belt isn't moving the shaft.
a. Remove the top of the sewing machine.
b. You will most likely have to remove the panel on the end where the hand wheel is.
c. Turn your hand wheel to see if the belt is moving the shaft or is it broken?
d. Replace if you need to. (look at wear). Loosen the motor.
e. Make your motor run (foot pedal) slowly. Tighten the belt by pushing on the motor while it is running. When the motor is placed at the right place the motor will be moving with very little drag. (This will need a listening ear)
f. At this point tighten motor and retest for the speed and drag.
Mar 21, 2015 | Sewing Machines
Why won't my old manual singer sewing machine needle move?
1. Disengage the bobbin winder.That is done by moving the arm away from the center wheel. 2. Tighten the hand wheel. When you tighten you should have resistance like a jar has. If this doesn't then continue. 3. Loosen the small screw attached to the hand wheel center lug. Now, move the hand wheel into a position where it will tighten. 4. Go ahead and tighten the small screw. Now, it should move.
Nov 19, 2014 | Singer Sewing Machines
My model 120 Husqvarna Viking sewing machine will not start sewing with vigor. It lugs through the first two minutes of stitching with virtually no power then very gradually picks up speed. How do I fix...
Good luck.
Jan 25, 2010 | Husqvarna Viking 1
Hand wheel will not turn
A FRIEND GAVE ME A SUPERLOCK 2000 WITH THE SAME PROBLEM. THE HANDWHEEL WAS HARD TO TURN AND MACHINE WONT RUN WHEN PLUGGED IN. I OPENED THE SIDE COVER WHERE HANDWHEEL IS LOCATED. FOUND THE BELT WAS DRIVEN OFF THE MOTOR. PUT ON THE BELT ON THE MOTOR, OILED THE MOVING PARTS.
WOKRING GREAT NOW.
Apr 30, 2009 | White Sewing Superlock 2000 ATS Mechanical...
Sewing Machines Logo
50 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
