I need to work when i get this - Computers & Internet
My keypad used to work, changed battery, does not work, bought new keyless pad and still wont work, remote in truck works
Need to reset/re-program it as specified in the user manual. When the keypad loses power during the battery change it loses the original settings and need to be reprogrammed. New keyless pad also need to be programmed to link with the receiver.
Jan 12, 2016 | Building Materials
I deleted my work email account and I need it restored what do I do
Hi Daphne,
SInce this is your work email.. we need to know a few things..
1. Are you using your home email service to receive your work emails? If so, you will have to contact your I.T. dept and get the configuration to have it setup again.
2. If this your work email account on your work laptop... you will need to contact your I.T. dept and they will correct it.
Jan 11, 2016 | Computers & Internet
Fan will not work in 1998 cadillac deville so no heat
1- check your fuses 2- if your thermostat needs to be replaced it can cause the fan to stop working because engine never gets hot enough to allow fan to come on. 3- your fan blower motor could be defective and needs to be replaced 4- your fan blower resister may need to be replaced. The fan will still work on high in most cars, but not work at all in others 5- if you have automatic temp control, the control panel may need to be replaced. These are expensive, so get a replacement at junk yard.
Feb 28, 2015 | 1998 Cadillac DeVille
I need a universal remote that works for RCA tv.....
Smarter if it is available to buy an original remote--universals will if they program at all be missing many needed features....
Oct 29, 2012 | Televison & Video
Need help with altec lansing ada 745 4.1 speakers
Does the right front speaker need to work in order for the whole speaker system to work?
The whole system can still work with or without it.
Here is an additional tip how to ..... Computer Speakers
Sep 29, 2012 | Altec Lansing ADA745 4 Speakers
Freezer working, fridge not working .hotpoint
Hello Sir, I think we need some more info about what section of the Fridge is not working. Let me assume that the Problem is that the Fridge is not cooling ( as you raised that point that the Freezer is working. If that is the problem, then there are 2 things that can be Faulty:-------
  • The compressor is bad or not working. In this case you need a new compressor or repair if the fault is repairable.
  • The Thermostat is bad or not working. In this case, call a Technician of the associated brand. They will repair or replace as needed.
Another thing, if the Fridge is fully not working, then the fault is in the capacitors or the Main Control Board. Kindly call a technician for the steps needed to rectify the issue.
Thank you Sir, Have a nice day.
Oct 16, 2009 | Electrolux Freezers
Window on the driver side does not work. I did check the switch and it does work. I know that there are relays for the windows. I just need a diagram of the windows and also I am having troubles with the...
window on the driver side does not work. I did check the switch and it does work. I know that there are relays for the windows. I just need a diagram of the windows and i need a relay or where can i find it ?
Jul 26, 2008 | 2002 Ford Windstar Cargo
I need a code to make my remote work my tv
i have a rca tv and a magnavox universal remote and i need codes to program
Jul 08, 2008 | Televison & Video
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
