I have 1500 watt'5200 BTU Fire place cabinet heater. It's120VAC.60 Hz pulling12.5 Amps.I've plugged into 3 different wall outlets and all the outlets and plugs get super hot and kicks the breakers.
    Top Expert:
  • Heating & Co... Master
  • 48,384 Answers
Dead short in the wire or unit
have it check by an accredited electrician or repair shop
Posted on Apr 18, 2017
Testimonial: "Thanks! I just bought a new plug and 3 new outlets."
  • 1 more comment
  • Bill Boyd Apr 18, 2017
    have you got it plugged into the correct voltage outlets
    are you sure that the outlets are 120 v and not 240 v
  • Thomas Dunville
    Thomas Dunville Apr 18, 2017
    Yes I've got it plugged into a living room and dining room wall outlet. 120v and its a 120v heater.It's one of those omish heaters I bought at Home Depot.What kicks the breakers? The heat or the short.
    the short or the insulation failure check the breaker amp setting as you have a current draw of 12.5 amps per unit so the breaker has to be at 15 amps
    if it is 15 amps and is still tripping get in an accredited electrician to test the circuit and the unit
Trying to find the right fuse for a eden World Tour 800 bass amp
Well, hope this helps you.
Fuse Requirements:
USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
No lights upstaires circuit breaker keeps tripping
Jan 2013
1) Move wire to another same-size circuit breaker to eliminate bad circuit breaker as suspect.
Do NOT increase size of breaker or it will cause fire.
2) Put hand on each appliance and outlet to see which ones are warm. Outlet should never be warm or hot. Replace outlet. Inspect wires for loose and burned connections.
3) If the breaker is good, then add up total watts being used by checking watt rating on each device. 100 watt light bulb is 100 watts. Big screen TV has a label that shows 300 to 500 watts. Computer has label. Space heater has label showing 1500 watts. Iron has a watt rating label. Take total watts and divide by 110Volts and this will give amp load. Total watts used = 2000 and then divide 2000 by 110 volts = 18.8 amps
Compare amp load with circuit breaker.
20 amp circuit breaker has 80% safe maximum, or 16 amps.
If amp load is 18.8 amps, then 20 amp breaker is starting to get hot, and weak breaker will start tripping.
If amp load is 18.8 amps, and breaker is 15 amps, then you are overloaded and breaker is feeling the heat, and tripping because of heat.
Solution is to reduce amp load.
4) If you have short circuit, that can also trip breaker.
Unplug everything and then plug things back in slowly to see which plug or appliance is causing the problem.
Jan 18, 2013 | Electrical Supplies
I want to add an under-counter auxiliary water heater to my 15A dishwasher circuit. I need to install some sort of relay to cut out the water heater when the dishwasher is being run, to avoid overloading...
If I understand correctly you have 15 amp breaker with 14gauge wire.
Total watt capacity of 15 amp breaker is recommended at 80% rated load = 12 amps
You want to connect two appliances to same 15 amp line.
1) You have 6 amp Dishwasher that draws 720 Watts
2) You have under the counter water heater with 1500 Watt element that draws 12.5 amps.
3) Combined load is 18.5 Amps and 2220 Watts, approximately
So you do not want dishwasher and water heater turned on at same time.
Makes good sense.
> Easiest thing would be to put water heater on ordinary wall switch located inside sink cabinet.
Back when garbage disposals first came out, garbage disposal switch was inside sink cabinet. You opened cabine door and flipped the switch.
> Next solution would be to put water heater on a timer located under the sink. There are different timers. In-wall timers and box-type
In-wall timer would need relay/contactor
A battery operated timer like the ST01C would not need to be reset after power outage
Here are instruction pages for selecting and installing the relay/contactor.
Add a comment any time.
Box-type timer like T101 120Volt timer. This timer needs no relay/contactor.
Timer needs to be reset after power outage, but operates on ordinary 120V power, and is simple to install.
> There is no easy way to wire the dishwasher and water heater together so one is certain not to operate when other is turned on. There are likely electronic control panels for that project. But since you know the hours when dishwasher is likely to be ON, then set water heater timer to turn OFF during those hours. Water inside tank will stay hot for a couple hours, so there is no loss.
It sounds like you are a solid electrician.
If needed, add comment any time for more assistance.
Dec 14, 2010 | Rheem 2.5 Gallon Electric 120V Water...
I have a trailer house that has a 100 amp breaker box in it. I has gas for heat, water heater and stove. I am changing them to electric. Will I need to change the panel put to a 200 amp.
Its probably not a bad idea. Thats alot for a 100A panel to handle, a range needs a 50A, a water heater needs 30A, and the heat will need a 50A or a 60A breaker... Plus whatever else is in the house will be a bit more than the 100A service can handle. But if you don't have the money it will do for a while because for the most part they won't all be pulling at the same time. Word to the wise get at least a 30 space panel when you upgrade, I always install a 40 space panel because for the cost difference its well worth it for future needs because you'll fill it up quicker than you think and you'll have space for anything else you may want to add later on. Hope I helped
Dec 09, 2010 | Your One Source Homeline Circuit Breaker
De Longhi electric heater, "The Incredible Heat Machine" (2 ft. high, 15 in. long, 6 in. wide), has 2 buttons, 1 for 600 wats, the 2nd for 900, for a total of 1,500 watts. Has worked fine for years. The...
With a new plug and a new outlet it leads me to believe the machine is getting older, dirtier, and drawing more amps than the wires can handle. If disassembling and thoroughly cleaning is doable or in your mind, worth it, that's what I recommend. Otherwise it's in your best interest, being a fire hazard, to replace it.
Jun 25, 2017 | DeLonghi Heating & Cooling
For a/c unit, is there an adapter available or do I need a new plug cord
Actually you should buy and install an AC wall outlet. An AC uses more amperage than most any other appliance due to the fact it has 2 motors the compressor and the blower / fan motor. An AC wall plug has larger terminals so that the plug does not ever heat. Changing the cord to a different and smaller terminal plug is a bad choice due to the danger of overheating the wall outlet terminals. You can buy the AC horizontal terminal outlets at any hardware store. Unless you have a 110V AC unit you will also have to run a 220V #10 Romex (3 wire) with ground to the outlet to be in code.. An AC unit 1 HP (10,000) BTU or larger requires over 15 Amps for start up. Those that are 20,000 BTU or larger obviously require more than 15 amps as a power source.
Thanks for using FixYa.
Jun 01, 2010 | Heating & Cooling
Drawing current but not producing any heat.
I am assuming this is an electric wall mount heater, if the unit is drawing current then it should relate to heat as 3.41 btu is = 1 watt.
take the voltage reading and the amp draw and mutiply them to determine the wattage eg; 240 volts x 20.8 amps = 5000 watts = 17,050 btu. if the unit is fan assited and you are drawing 1 to 2 amps this would indicate the fan is runnning without the heat element being energized hope this helps
Nov 04, 2009 | Fahrenheat (FFH1614) Wall Mounted Panel...
The heater plug melted
Induction coil heaters draw very high amperage (12-14 amps) when turned on. If your outlet is worn or old the heater plug prongs will not have a good connection and the current will jump or arc from the outlet to the heater plug prongs. This arcing causes tremendous heat, enough to melt the outlet and the cord end. First thing to do is change the outlet.
Jan 31, 2009 | Dimplex Compact Electric Flame Stove...
Connecting 240 volt singer baseboard heater
Need front grill for singer model WJA-12 wall heater Cat # 9756-A
single phase 60 HZ
240 volts 5.2 Amps
1250 Watts
Where can I find it?
Nov 28, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
