Question about Baby Gear
I need the plastic part that goes on each end of the mattress support frame labeled G. 2004 crib
SOURCE: cosco crib assembly
have a crib that was given to me so dont have instructions
Cosco Sleigh Crib
Model # 90242
please help!!
Posted on Sep 01, 2008
pingmoon
SOURCE: corner cribs
I am selling my whole set, the crib, mattress and bedding on ebay! Loved it, but do not need it anymore. It will be posted there in the next few hours. Just type in Corner Crib Nautical into the search. Local Pick up only.
Or contact me pingmoon@tampabay.rr.com
Posted on Jan 20, 2009
  • 10865 Answers
SOURCE: How to lower the mattress hight of a Pali Crib
http://www.pali-design.com/index.php?path=customer_services&template=instructions&section=customer_services&subsection=instructions&page=instructions
you will find the info you need at the Pali address stated above.
Posted on Feb 10, 2009
SOURCE: need screws for cottage crib by rockland
1-800-933-7115
This is the number for replacement parts for furniture at jcpenney. i ordered new harware for my caden convertible crib
Posted on Aug 28, 2009
  • 150 Answers
SOURCE: How do I lower the mattress on my Bonavita crib quickly?
Most cribs have tabs on the rails of them .... take everything out .. bedding,mattress,etc. Take a look at the platform that the mattress lays in especially the corners.... You might see a hook at each corner that fits into a release tab unlock the realease tab and remove the hook. Do this for each side and reinsert the hooks at the correct level in the crib... If this is not the case you may need to look at the owners manual... But I think you should be able to get a good idea about how it lowers when you remove all the bedding out of the crib..... good luck
Posted on Oct 19, 2009
What is the length of elastic that goes in the crib sheet?
If you're sewing your own, it completely depends on the mattress dimensions. You'd measure the fabric for the mattress dimensions, leaving enough overhang on the fabric to make an elastic casing for it, put a safety pin on one end and keep pulling until it cinches enough to be secure around the mattress, then you overlap it about an inch with the beginning and stitch those together.
Oct 05, 2014 | Baby Gear
The bolt type frame that holds the mattress broke and we need to know where we can get or order another one for this crib
Products America carries several different styles of mattress spring frames. Visit our website at www.productsamerica.com to review our selection of mattress spring frames.
You can contact us by calling us at 800-205-9642 or 800-772-1041. You can also email us at parts@productsamerica.com.
Apr 04, 2012 | DaVinci Kalani M5501 Crib
What type of full size bed frames do i need for luv 5 and 1crib?
Regards, Tony
May 22, 2011 | Toys
When you turn your crib into a full size bed, do you use a mattress set (with the box spring) or just the mattress?
Just the mattress should be fine since it already has a "bed frame". But since a lot of people have trouble converting cribs into day beds or full-size beds, you are probably better off getting a box spring for that. Also, find out if you have the parts that you need. There have been a lot of recalled Simplicity cribs and the parts for those recalled items are no longer available.
http://www.bestmattressreviews.com
Sep 23, 2010 | Simplicity for Children 4-in-1 Convertible...
Put together
The metal hinges on the corners go upward. The ends should have little nubs that slide into holders or it will have hangers like a regular bed. Otherwise the mattress support may bolt to the frame. Consider going to
http://www.coscojuvenile.com/usa/eng/ and search for instructions
May 09, 2010 | Cosco 2-in-1 Sleigh 10121 Crib
I need the plastic side pieces the crib matress frame sits on
you need a mattress frame on you crib. yes you can have it just go to
this site: http://www.bestmattressreviews.com/simmons-mattresses.html
there it may help with your problem.
regards,
Feb 05, 2010 | Simmons Mattress Matino - Natural Maple...
How do I attached mattress spring to crib base
The above picture is how our Jardine Enterprises crib attaches the mattress support to the frame. I am thinking you need the bolts to make your crib work. And that might be a chore unless you are very handy with hardware. Also, being a new parent ourselves, I would recommend against anything but the safest crib for your child. Call the original owner--see if they can find the bolts/hardware, if not get a complete unit if you can afford it, it may cost more in the short run, but may save a serious injury or worse. Also, if you go the used route see if it has been recalled, you can start here:
http://www.thenewparentsguide.com/choosing-a-baby-crib.htm
Jun 05, 2009 | Evenflo Jenny Lind Crib
Changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
jmsmith2003@msn.com
Sep 15, 2007 | Childesigns Carrollton Crib
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
