Question about Kyocera Office Equipment & Supplies
All the lights on the Kyocera FS 1300D are flashing. I have turned everything off and unplugged it all, pulled it all apart to see if anything jammed...Still all the lights are flashing
SOURCE: PCL XL error
try to go to property then setting device button PDL and try to put pcl 5e
Posted on Mar 10, 2009
  • 3 Answers
SOURCE: Can you help me with kyocera fs-1030d
If a paper jam occurs while printing, the printer notifies it by the following combination of the four indicators. Remove the
jammed paper . After removal, open and close the top cover once to initialize the jam sensing
Posted on Sep 18, 2009
don_farr
  • 1018 Answers
SOURCE: how do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
Posted on Nov 19, 2009
n25an
  • 622 Answers
SOURCE: Kyocera mita ecosys fs-1010 - Flashing light red light and clicking sounds
clean or replace the rollers that feed paper into the copier... use rubbing alcohol or isopryl alcohol to clean them...
Posted on Dec 25, 2009
Comp-U-Doc
  • 148 Answers
SOURCE: the 3rd light on my Kyocera FS-1020d is flashing red, no printing
The flashing is a code. Depending on if it is flashing fast, slow or so on...
Turn to page 32 of this manual for more information.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
Posted on May 15, 2010
Drum reset procedure kyocera 1300
Unfortunately, you cannot reset the page counter on any kyocera printer. Unless you have an eeprom reader with the appropriate software.
Jul 19, 2014 | Kyocera FS Office Equipment & Supplies
How to ingrese density
density adjustment are made from within the print driver. you may have a printer issue if your prints are washed out or light.
Oct 11, 2013 | Kyocera Fs-1300d Printer
Hello, I have problem with Printer Kyocera FS-1300.. when i connect it to pc, it starts to print some symbols, like smiley face on left corner of page, and i cant stop it, when i disconnnect my device...
Hi. I would suggest that you unplug the printer, reinstall software and check you computer for viruses. If i continues, try letting it print out. maybe someone set so that 30 pages with a smiley would be printed next time you plugged it in. I how this will fix you problem.
Jun 08, 2011 | Kyocera Fs-1300d Printer
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
HELLO!!! How do I reset a Kyocera FS-1300d networks card to factory settings. Thank you very much. hector
Your printer comes with a software CD. Run the CD there's an option to reset the printer.
Dec 10, 2010 | Kyocera Fs-1300d Printer
The 3rd light on my Kyocera FS-1020d is flashing red, no printing
May 14, 2010 | Kyocera Mita FS-1020D Laser Printer
How do i print envelopes on a kyocera ecosys FS-1300d
Don
Nov 19, 2009 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
PCL XL error
Sep 11, 2008 | Office Equipment & Supplies
239 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
