Wall outlet is getting hot along with the units plug,and its setting breakers off
  • Heating & Co... Master
  • 16,698 Answers
Replace the outlet. It has a bad internal connection that is causing resistance and is heating up like an electric fire element. Don't use that socket until you replace it due to the very grave risk of fire.
Posted on Apr 18, 2017
Testimonial: "Thank You! I just bought a new plug and 3 new outlets."
  • 1 more comment
  • Michael Barrett
    Michael Barrett Apr 18, 2017
    Or the problem could be resistance (or bad connection) in the plug, in which case replace the plug or the whole cable and plug.
  • Thomas Dunville
    Thomas Dunville Apr 18, 2017
    Thanks! I just bought a new plug,along with 3 new outlets.
  • Andrew Taylor
    Andrew Taylor Apr 18, 2017
    Great, better safe than sorry ??
Whirpool cabrio does not run or fill
check the power supply to the unit. if no voltage is found on the unit . check the wall outlet.no power at the wall socket ?? check the breaker box for tripped breakers if breaker to the wall outlet is off but good ,leave as is . check for grounds at the unit . if no grounds are present , turn on breaker . if it breaks with the dryer still not plugged in , search for any appliances connected on that line and unplug all. plug in the dryer then start it .if breaker opens , something is wrong with the dryer. call a qualified technician . thanks .
Sep 07, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Switch /comb gets hot in wall
This is fire hazard.
Call electrician.
What is plugged into outlet?
Are wire and breaker sized correctly?
Do you have aluminum wire?
http://waterheatertimer.org/Color-codewire.html
Otherwise turn off circuit breaker, pull out device and inspect for melted wires.
Use nose to find source of heat and burning.
Inspect if you have aluminum wire. Do not use aluminum wire.
Aluminum wire will burn down your house today.
Use only copper wire.
Replace combination device with new.
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
Apr 17, 2013 | Pass & Seymour #691CC6 Comb...
When i plug in motor humbs and then kicks bracker
More than likely you have it plugged into a standard wall socket and the breaker that the spa is on has other things like lamps or blenders on the same breaker. If you have a hot tub plugged into a standard outlet you need to be sure it's the ONLY thing on that breaker or else it will trip. Your outlet is 110 and that spa need 120 so it's pushing it to begin with.
Feb 28, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
My airconditioner has been on energy saver for almost 2 days and will not come on what should be do
If this is a window or wall unit. Turn the Master ON/OFF Switch to OFF. Unplug the unit and wait 12-15 minutes. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls on anything except energy saver. If the unit then operates as it should, let it run for at least an hour before switching it to Energy Saver Mode. If that's the way you want to operate it. If it doesn't restart and run like it should or it shuts OFF on Energy Saver Mode, there is a problem with one of the setting sensors and needs to be replaced.
Also, while you have the unit unplugged, check the outlet to make sure it's still active. You can do this by plugging in a lamp. If the lamp doesn't work, the circuit breaker for that outlet has been tripped in your home's circuit breaker panel and needs to be reset. When you plug the AC unit back in and it trips the breaker again, there is an electrical short or overload in the AC Unit.
Please keep in mind everything I suggested is based on your AC being a 120 volt window or wall unit.
Hope this helps you solve the problem.
Apr 13, 2011 | GE Heating & Cooling
We had a power outage and now our Maytage Gemeni stove won't go back on. Can't test the outlet, of course, since it's that weird huge plug, but all the other electricity is fine. The oven is completely...
Hi!!
Check breaker box for a tripped Double Breaker, probably 30A, If breakers are OK, unplug unit from wall outlet and wait 15 min. to reset the control board, plug unit it back up and check Range. You can check for power at the outlet using a voltmeter set on the AC mode.
Keep me posted!!
Dec 04, 2010 | Maytag MER5550 Electric Kitchen Range
Dryer wallplug heats up
you may have aluminum wiring going from your fuse box to the wall plug (older house) .. if this is the case then you have to have a special wall plug that is approved for aluminum .. if you use a standard wall plug then you will get what you are seeing (it gets hot after a few years) .. the connections work loose and start to get hot .. if you have copper wire then you might also have either loose connections or the springs that make contact to the plug have lost tension .. make sure you turn off the circuit breaker before doing anything inside the wall plug box .. make sure water hasnt damaged things inside the box .. once the box has gotten hot the integrity of the spring contacts cant be trusted .. (they lose their spring force when they get hot) .. so no matter what kind of wiring you have you should replace the wall outlet .. if you have aluminum wire (white looking) then get an outlet that is aluminum certified .. if you have copper wire (orange color) then replace the outlet with one that has a rating of 20 amps .. that should fix your problem.
Oct 23, 2009 | Speed Queen AGS28AWF Gas Dryer
Fan works, but if A/C turned on, trips breaker within a few minut
You need to verify if the problem is the unit or the breaker.  To do this, you will need to measure the current it is pulling from the power source.
If the unit is pulling too much current, then the unit is the problem.  If the unit is pulling as much or less than its rated current draw, then the circuit breaker is worn out.
The units WILL pull more power when hot outside.  It should not trip a breaker unless something is wrong with either the unit or the breaker.
A current draw test will tell you for sure.
If it's not the breaker, then it's probably low refigerant causing the issue.
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
Window unit trips circuit breaker
If your Plug is getting hot there is a voltage drop where the heat is generated. On these wall outlet recepticals there are two different methods of connecting the wires. First they strip the end of the wire and plug it into the back of the receptical . The second method is to strip the wire and attach it to a screw terminal . This is the best method for any outlet with a motor running from it.
For an example draw a straight line and then draw a circle that comes in contact with the line. Look and see how much contact area you have where the circle touches the line.
Jul 02, 2008 | GE AVX10AD Air Conditioner
AFTER 10 MIN OF TURNING THE HEATER ON OUR POWER OUTLET TURNS OFF WHAT COULD BE THE PROBLEM?
Not knowing what kind of heater this is, I will assume that you are referring to a small plug in 110 volt room heater since you mention power outlet. Check the amp rating of your heater verses the breaker. Remember if it is a wall plug that there are other plugs on the same breaker. Breakers work two ways, as an over current (amps) and thermal protection (heat). It could range from too close of a current draw for the breaker and heating it up or a loose wiring connection at the breaker or wall plug. Loose could also be the problem for a central unit. After it runs a while place your finger on the front of the breaker to see if it feels hot, it should not get warm
Apr 25, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
