Question about The Computers & Internet
How long do you charge the context battery backup befor I get to put it to use
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
Usual it be charge for 24 hours.
Posted on Apr 18, 2017
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    No indicator lights after replacing battery
    I have one question, have you connect the battery terminal correctly the first time you install your new batteries? If not, it might be your battery fuse is blown during the process :) check your UPS battery fuse.
    Dec 30, 2012 | APC Conext 900VA (cnb900) UPS System
    It's been 4 days ago since my cellphone gets a problem bout sending message.,..every time i send a message the message "Message Sending Failed" immediately pop out
    ok before contacting your provider try taking out the sim card and battery. while there out i want you to put the sim card in before the battery then after sim is in put battery let it sit for 2 minutes then turn on. (also before starting make sure battery is fully charged, if not charge it before doing anything. Or if you have a backup battery use that, make sure its fully charged also)
    If this is a new service, and your just recently using it, make sure #1 you have the data package activated from your provider #2 make sure they dont have your account locked because of an unpaid or late bill. cell phone operators are alowed to lock services if bill is late or not paid on time. there grace period is only 30 days max
    Mel
    if this helped please spend the time to rate the service
    Sep 27, 2010 | Computers & Internet
    Short backup time
    Suspect battery failure/faulty cell in a batt
    Remove batts and check outside unit
    charge up to around 2.27V/cell then check discharge on each batt (12V car lamp is good dummy load)
    faulty one will be obvious.
    MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
    Check you manual for safety procedures, BEFORE working on Batteries.
    hope this helps
    thanks for using Fixya
    Jul 06, 2010 | Powerware 9120 UPS System
    Change the backup battery in MC9060
    Hello mis1539. I think I can help you here. First: are you sure the backup battery is defunct? Bear in mind that the backup battery takes about 15 hours to fully charge and will discharge if the main battery or power source is disconnected or goes completely dead for anywhere from 30 minutes to a few hours. If the backup battery discharges, the process starts all over and the backup battery will need to be charged for 15 hours again. If you think the backup battery may have discharged at some point, it could be that it never full re-charged so it will discharge and lose your settings (cache/flash memory) almost instantly. It is worth mentioning that about 95% of my clients that have this problem have fixed it by simply making sure that the unit is in it's cradle, with the battery in and charging overnight to fully recharge the backup. Again, I really would implore you to give this a shot before resorting to cracking open the unit and getting to the backup battery (which is no fun task, I assure you). If this doesn't work for you, please let me know and I can help you further. I hope this solves your problem. Good luck!
    Sep 23, 2009 | Symbol MC9090 Mobile Computer Portable...
    Battery problem
    its a battery problem try exchange it
    please vote
    Jul 25, 2009 | Dell Inspiron 2200 PC Notebook
    The phone is not recognizing the backup battery. can someone please help me on how to charge or replace the backup. battery
    The backup battery is located inside the phone and canno be replaced by normal methods. the phone needs be disassembled and the battery are solded on the board.
    the lifetime of these bateries are very high, maybe 5 or more years, and the charge occurs every time when you charge the phone.
    Try to leave your phone charging for more than 3 hours, and if the battery dont charge, try a master reset on it.
    If ater all, the battery dont charge, maybe you make some mistake or shorted some circuit. Take apart your phone again and re-check all the steps to reassembly.
    Good luck
    May 23, 2009 | i-mate JAM Pocket PC
    HOW TO CHANGE OR CHARGE THE BACKUP BATTERY?
    y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
    Feb 17, 2009 | HP iPAQ h6315/h6365 Pocket PC
    Dell axim x5 back-up battery
    It is a knows issue for the backup battery not to take charge once they reache 0%. The backup battery is a pretty crappy NiCD cell. As the job it is supposed to do is pretty important I recomand to have it changed. For most PDA's this is a standard 3V battery. You should have your pda dissasembled and either have the battery manually charged (to see if the PDA can handle it later) or simply have it changed. This shouldn't be an expensive repair. For more info, feel free to reply. Good luck.
    Feb 16, 2007 | Dell Axim X5 Pocket PC
    Computers & Internet Logo
    27 people viewed this question
    Top The Computers & Internet Experts
    tim brauer
    tim brauer
    Dilum Senarath
    Dilum Senarath
    Are you a The Computer and Internet Expert? Answer questions, earn points and help others
