Question about RCA Televison & Video
My rca sound bar is not working with my tv insignia
SOURCE: insignia lcd tv
http://www.fixya.com/support/t382563-insigni_remote_codes
Posted on Jun 10, 2008
walesarumi
  • 6993 Answers
SOURCE: Im trying to connect my
You will be needing a RCA Digital TV box converter or Digital RCA TV box converter. This converter will be the link between the Sound bar system and TV.
You should find this converter in any electronics accessories store within you vicinity or check walmart store close to you or order it online from walmart (But I don't recommend ordering online because of it's problem sometimes).
Check the back of the converter, it should have an input for Digital and RCA output and vise-a-vise.
Take a look at this Walmart link; http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
I hope you understand the above.
Good luck.
Posted on Feb 26, 2011
  • 41955 Answers
SOURCE: My sound bar hooked up directly to my tv has no sound
You may have to go into the Bravia setup procedure and opt to disable its internal speakers
Posted on Nov 18, 2012
Testimonial: "You do"
  • 11 Answers
SOURCE: RCA model# L46WD22YX11, TV works, Sound bar on screen moves but no sound. Any suggestions.
Sounds like ( pardon the pun!) one of the TVs chops on the circuit board are gone. Costly enough repair, how old is the T.V? Is it under warranty?
Posted on Jan 18, 2015
  • 314 Answers
SOURCE: Connected an RCA sound bar to my RCA tv an the remote control wont work anymore
You may have situated it so it is blocking the pickup for the remote. Your remote is talking but the TV can't hear it. Make sure no part of the front is blocked by the sound bar.
Posted on Apr 02, 2015
Testimonial: "Thank you Tom:The problem was corrected taking off the batteries from the sound base remote. Apparently being the same brand, the two remotes were interfering with each other. I am now using the tv remote to control the volume in both systems and when fine tuning the sound bar, I use its remote solely for this purpose."
Once I have my sound bar (RCA Brand) hooked up to my T.V. (Insignia), how to I get sound from it or turn it on?
How did you connect the sound bar to the TV? The remote that comes with the sound bar should control everything... PLEASE read the operators manual first...
Jul 25, 2017 | Televison & Video
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
Apr 02, 2015 | RCA Televison & Video
Jan 18, 2015 | RCA Televison & Video
How to fit anb3530a lg soundbar to toshiba tv
trade your TV or Sound bar to something that is compatible. IE Make it work, No optical port find a sound bar that works with RCA, Make certin you have RCA audio outputs on your tv, if you want the sound bar than New TV
Jul 28, 2014 | Toshiba Televison & Video
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
Dec 25, 2009 | Insignia 200W Stereo Receiver
There is no sound on my insignia flat screen what do I do
Try hooking up the powered PC speakers to the AUDIO Line out RCA jacks to see if you get the sound there, if you do, then the problem can be in the power amp section (make sure to check the on screen sound setup menu that the speakers are not set to OFF), if no sound at the RCA jacks either, then the problem can be in the sound processor circuit in the main board.
Nov 09, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Surround sound
Make sure the RCA cable is going from an audio OUT on TV or DirecTV box to a red/white (non-digital) audio IN on surround sound or home theater system.
Dec 29, 2007 | Insignia NS- 27" TV27 TV
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
