Question about Yamaha Televison & Video
What do i need to do to program a mini direct tv box to my yamaha rav360
ladywinn
  • 5138 Answers
SOURCE: Need code to program remote to work with Direct TV brand box.
I have the codes you need to set direct handunit for your TV.11145-10145-11960-11904-11445-11345-11045-10797-10583-10577-10413-10409-10279-10227-10173-10151-10097-10095-10056 10038-10032-10016-10105 Switch slide mode to TV make sure tv is on now press and hol MUTE&Select together untill it flashes green now enter code then press power if set turns off that will be your code if not repeat steps untill TV powers OFF.
Posted on Feb 17, 2009
petraman7
  • 1175 Answers
SOURCE: i am looking for programing codes for my yamaha
Try the Yamaha Consumer Electronics website
They have ALL their manuals there
Posted on Jan 26, 2010
tthekraut
  • 374 Answers
SOURCE: i need to program 2 direct tv remotes to operate
here is a link with the code sets for this remote: direct TV remote codes
here is a link to programing guides: Programing a remote
choose your remote type and follow the instructions to program it.
Thanks and I hope I helped. Send a message if you have any questions.
Posted on Mar 17, 2010
  • 35 Answers
SOURCE: need to program to use
Click here to download manual.
Codes for Direct TV Receiver are:
DirecTV 0392, 0566, 0639, 0247, 0749, 1749, 0724, 0819, 1856
Not sure what brand of TV you have but codes for TV are on same page as Satellite Receiver codes (Page 19).
Posted on May 10, 2011
  • 59 Answers
SOURCE: I have a direct Tv remote and i need the codes to a RCA tv model f27676bc, i neeed to program the remote without the direct tv box
try these codes. 18, 59, 67, 76, 77, 78, 92, 93, 94. one of these may work.
Posted on Nov 26, 2011
My direct TV remote was in the wrong mode when I was inputting and I lost the sound.I have a yamaha htr 5730 receiver and I have no idea what I have done, but I want my sound back, but how?HELP please
Remote has nothing to do with you sound unless you had it programmed to turn the unit on. If that is the case then contact direct TV to program it again. If not the case, just turn on the Yamaha and select the proper input and you should be good to go.
May 23, 2016 | Yamaha Audio Players & Recorders
How do I set up new Yamaha RAV360 remote control for my Yamaha HTR6090amp/home theater?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
May 20, 2015 | Yamaha Televison & Video
My (Cable Service) wire feed is directly behind my HDTV and hooked up over my fireplace . The Rxv667 is located on a side wall book shelf. I have A HDMI wire running to the TV from my receiver. Do I need...
Is there a set top cable box, or are you feeding the cable directly to your HDTV (coax directly to the TV). If you are feeding cable directly to the HDTV then you don't need HDMI. There maybe exceptions, but most TV's don't have HDMI output. The only thing you need to run from your TV to the Yamaha is an audio cable. I assume your HDTV has an optical audio out (either TOS or coax.... Your Yamaha will accept either). Connect the optical audio cable to the AV4 input on the Yamaha. This way when you hit the TV scene button on the Yamaha remote, it will select the AV4 audio input (the default for the TV scene). The optical cable will feed the full audio signal, so that the Yamaha can pass through the surround sound or use the decoder as appropriate to feed your 7.1 or 5.1 speaker system.
If you have a set top box, you may be better off moving that near the Yamaha. In this case, cable goes to settop box, output of set top box via HDMI or component video (RGB) and optical audio to the Yamaha (if you use HDMI Input 2, and AV4 for the optical audio (if necessary), the TV Scene will select the appropriate inputs) and then an HDMI to your HDTV.
In case one, you may need to setup the TV to process the audio appropriately. I have experience with Panasonic Plasma but thats about it.
Feb 24, 2011 | Yamaha RXV667 Receiver
I need to program 2 direct tv remotes to operate tv's as well as the direct tv box
Mar 17, 2010 | RCA DIRECTV Satellite Remote Control
Setting up DVR, Receiver & VCR w/out cable box
For TV audio thru the receiver, you will need to run an optical cable or RCA analog audio cable from the "Audio Output" or "Monitor Output" on the back of the TV to the CBL/Sat input on the Yamaha. The VCR goes to Video 1 on the receiver and the DVDR will go to DVR/VCR2 on the receiver. If you want to pass Video thru the Yamaha to the TV, use the "Monitor Output" on the Yamaha if it's at least "Component Video" if not, connect your video sources directly to the TV and audio to the Yamaha. Hope this helps. If you need further assistance with this, post a comment and I will help you further.
Sep 26, 2009 | Yamaha HTR-6030 Receiver
How do you change the tv from CATV to just TV in the programming?
the tv doesn't need to know that the signal is coming from a dish, so the use of catv while using direct tv should be okay. it seems that the problem may be with where you are making the connection from the direct tv box. plug it in where you would a cable box cable.
Jan 24, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
Jan 10, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
