Question about Health & Beauty
If I have been in an area where legionnaires disease has been noted - how quick or slow before symptoms show
What is Ischaemic heart disease please
Ischemic Heart Disease, also known as Coronary Artery Disease, is a condition that affects the supply of blood to the heart. The blood vessels are narrowed or blocked due to the deposition of cholesterol on their walls. The major risk factors are smoking, diabetes mellitus and cholesterol levels.
For a more complete explanation, please refer to this link:
Ischemic Heart Disease Treatment Causes Symptoms Prevention
Nov 03, 2017 | Health & Beauty
Smell emanating from the groin
A variety of conditions can result in this. I am providing a link to the Mayo Clinic. Click the diagnostic lnks there.
The Mayo Clinic site has a symptom checker which you might google if you find the link below too broad. It enables you to focus on specific areas of the body. I suggest you make use of it.
https://www.mayoclinic.org/diseases-conditions/sweating-and-body-odor/symptoms-causes/syc-20353895
Symptom Checker
Oct 21, 2017 | The Health & Beauty
What are the signs of kidney problems
"Kidney problems" is a bit non-specific, as it might mean anything from stones to cancer, but it could be found with
- elevated blood pressure
- unusual u r inary habits
- frothy or odd looking u r ine
- swollen legs or ankles
- fatigue
- nausea
- bad breath and a metallic taste in the mouth
- muscle cramps
- pain around the kidney area
Kidney disease is sometimes silent, but there are good tests for it, so if you are concerned, see a doctor.
May 23, 2017 | The Health & Beauty
Symptoms of motor neurone disease
lack or controlled body movement
a full description is found by going google and typing in --- symptom of motor neurone disease--or by seeing your doctor for a proper diagnosis ( much better idea )
Apr 17, 2017 | Health & Beauty
Treatment of lyme disease
THE.LUCIFERIAN.DOCTRINE.PDF/ #3.1+
@DL: https://drive.google.com/file/d/1kes_eIbXPBjyW6pOFeplte6BWdrxbi8x/view
Jul 06, 2014 | Health & Beauty
What is legionaires disease
Is a form of pneumonia caused by any species of Gram negative aerobic bacteria belonging to the genus Legionella Over 90% of cases of Legionnaires' disease are caused by the bacterium Legionella pneumophila.
They thrive in static water for ex air conditioners with defective water drains or dehumidifiers.
Jun 29, 2014 | Computers & Internet
A/C condensor drain
don't mess with the drainage. it's highly toxic
Jun 09, 2014 | 2002 Isuzu Trooper
God of War 2 walkthrough in english, THE TEMPLE OF EURYDALE,
The Temple of Euryale
Down the stairs, smash the petrified Legionnaires to shatter them, releasing red orbs. Continue on to the right and quickly shatter the petrified enemies before they break free. You can use Golden Fleece to reflect the Legionnaires attacks back at them. Prepare to reflect when their weapon begins to glow blue and they leap up into the air. Start climbing down the ladder at the end of the hall. Down below, some petrified enemies break free and a hulking Minotaur appears.
Quickly shatter the Legionnaires that have yet to break free and then immediately turn your attention to the other enemies. The Minotaur is surprisingly easy to kill if you have a full magic meter. By using Typhon's Bane you should be able to bring the Minotaur down to its takedown stage. When the Circle appears over the Minotaur's head, approach it and press the Circle button to start the takedown. Press the two buttons that appear on screen then finally rotate the Left Analog Stick as shown to finish the beast off.
Unfortunately, once you have killed enough enemies, another Minotaur appears, but at least if you kill off the first quickly, you won't have to face two of them at the same time. For the Legionnaires use Plume of Prometheus (Square, Square, Triangle) and most importantly, use Golden Fleece to reflect their leap attack. If done successfully, you can damage the surrounding Legionnaires with the reflection as well.
After the battle, head through the doorway to the right of the ladder. This hallway leads to a lift. Grab hold of the handle and rotate the Left Analog Stick to lower the lift down to the level below.
PHOENIX FEATHER (12/30): When the lift has reached the bottom, jump up and attack the snakehead on the wall to reveal an unmarked chest that contains a Phoenix Feather.
The two lifts in this room influence the height of each other. Since the soldier removed the handle from the lift on the other end of the room, you must use the lift that still has a handle to raise the lift that does not have one. Raise the lift that you used to reach this room as high up as you possibly can while still allowing you to drop down from the lift to the room below. This raises the broken lift up to that same height, allowing you to then climb up onto the raised lift and scale the wall using the ridges along the wall
Feb 10, 2014 | Sony PlayStation 2 (PS2) Console
It wont install on vista. how can i get it to install on windows vista?
Unfortunately this program was not designed to be used with windows vista. here is the product description from Amazon.com PProduct Description AMA FAMILY MEDICAL GUIDE. Over 800 In-Depth Articles. Make Better Health Care Decisions! Based on the best-selling American Medical Association Family Medical Guide book, this fully interactive program offers comprehensive, easy-to-understand explanations of diseases and disorders, practical advice about preventive health care, and AMA-approved interactive diagnostic symptom charts.Glossary of Over 700 Over-the-Counter and Prescription Drugs. More than 650 Diseases and Disorders Defined. Over 150 Health and Wellness Tips. Where Does It Hurt The easy question-and-answer format of the symptom flowcharts take you from symptoms to diagnosis and puts quick, reliable advice at your fingertips. Be Smart. Be Prepared. Detailed lists of life-saving techniques, quick actions to take, and what to do in an emergency, could mean all the difference in the world to you or a loved one. Exercise Common Sense Clear illustrations and in-depth articles provide thorough information on health, nutrition and wellness. System Requirements for Windows. Windows 3.1x, 95/98, XP. 386DX, 33 MHz or better. 16 MB RAM. 12 MB free hard drive space. 640x480 display, 256 colors. 1X or faster CD-ROM drive. 8-bit sound card (will not run without a sound card). Speakers or headphones. Mouse.
May 02, 2011 | Dk Multimedia AMA Family Medical Guide...
Health & Beauty Logo
20 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
