Question about Miele Dishwashers
Miele Dishwasher 626 SC starts but no water is received and it stops soon after. Water supply is ok and has pressure. Main solenoid is also ok. Any suggestions?
    Habit-Forming:
    New Friend:
  • 108 Answers
Is the drain pump working? is it fed to a sink trap and end hasnt been cut out.i know but ive had this happen when sent to check a machine!pump is always first part of program
Posted on Apr 18, 2017
Why is my Miele dishwasher displaying "Open stopcock", even though water is flowing and I've cleaned the inlet filter?
There are 2 possible main causes for lack of water, given that you have checked water availability at the dishwasher.
1. The water solenoid valve in the machine is faulty or failed.
2. The motherboard in the control panel has a fault and needs replacing.
Unless you are a DIY'er I suggest you call a serviceman
Apr 06, 2017 | Miele Dishwashers
Water will not flow into the G 650 SC dishwasher. Power comes on and the dishwasher hums away but there is no water getting in - Guess it's the Solenoid on the tap end of the hoes
Could be a loose connection on top of the solenoid or a faulty coil on the solenoid if it's humming it's probably a faulty coil, contact Miele at fern tree gully rd scores by they will be able to send out a new coil for you, you need to be aware there are two different sorts of coils they go by colour either grey or red.
I hope this helps
Mar 31, 2014 | Miele Dishwashers
Miele G1182 dishwasher not working
Any water comming in to the dish washer area?? If not check the inlet water valve, they get clogged with sand from the water supply. They can also clog open, in which case the dishwasher will flood the floor with water afer about 3 to 4 imins of use.
Dec 19, 2012 | Miele Dishwashers
Miele G 2630 stopped working. It started and then just stopped now no power
Hi
The power issue with the Miele G2630 dishwasher is due to a blown fuse inside the dishwasher or due to faulty main board of the dishwasher. However, before checking internal components we can first reset the circuit breaker, make sure it is a 15 A breaker. If the breaker is fine then you'll need to disassemble the dishwasher. Try and dis-mantle the dishwasher from its place, before this remember to turn off power and water supply. And also check for the drain hose. After the dishwasher is dismantled, you can remove the back panel of the dishwasher and check for the blown fuse and also check for any loose connections on the power supply board. Inspect for burnt components on the main board.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 30, 2010 | Miele G2630SCiSS Dishwasher
WATER IS NOT COMING INTO DISHWASHER ALREADY FOLLOWED MANUALS TROUBLESHOOTING
check the following
1)check inlet water is ok.
2)solenoid filter block.
3)water solenoid defective.(check the supply is present)
4)boiler tank blockage.
Jan 09, 2010 | Miele Dishwashers
Dishwasher stops after 10 minutes inlet/drain light flashing
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele dishwasher
My O/H found a considerable amount of gunge in the inlet pipe; that seems to have solved it! Thanks for your interest.
Enid
Jul 21, 2008 | Miele 24 in. G646SC Plus Free-Standing...
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Open Questions:
Dishwashers Logo
42 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
