Question about Pool & Spa
Have older balboa hot with three control buttons light,temp, jets can't get it to lock in at 104 degrees. What do I to set it
4 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
  • 10 Answers
SOURCE: My balboa control is set
YOU CAN RESET THE PANEL ON SOME HEATERS HOWEVER WHATS GOING ON IS ONE OF THE FOLLOWING TWO POSSIBLITIES:
TEMP SENSOR IS DEFECTIVE (VERY COMMON)
OR
TEMP SENSOR IS TOO FAR FROM HEATER DEPENDING ON YOUR SET UP IT COULD NOT BE BE SENDING IN-ACCURATE READINGS TO HEATER BECAUSE IT IS FATHER AWAY, THE FATHER AWAY THE COOLER IT BECOMES, SO THE HEATER KEEPS RUNNING UNTIL IT THINKS ITS REACH 140 WHEN REALLY ITS 109
THE WAY TO TELL THE DIFF IS SIMPLE
IF THIS PROBLEM HAS BEEN GOING ON SINCE INSTALL ITS OPTION 2
IF THIS THIS JUST STARTED ITS YOUR TEMP SENSOR THAT NEEDS REPLACEMENT
- HOPED THIS HELPS--CHARLIE -- POOL PROS
Posted on Sep 03, 2010
MOTORWIZJ
  • 1338 Answers
SOURCE: Hot tub reads 104 degrees but actaully only 102, has a balboa cat200 controller
SEE IF YOU CAN FIND A NEW THERMISTOR THERE NOT THAT MUCH MONEY AND A GRAVY FIX ! ALSO DEPENDING,YOU MIGHT BE ABLE TO CLIP OR ATTACH A HEAT SINK TO THE PROBES HOUSING THIS WILL HELP BLEED OFF SOME OF THE HEAT FOOLING THE THERMISTOR .. YOU MIGHT HAVE A FLOW PROBLEM ALSO MAKE SURE THE PUMPS IMPELLER IS FREE OF DEBRIS
JAY THE POOL PUMP MOTOR REPAIR GUY LONGWOOD FLORIDA 32750 FREE MOTOR AND CAPACITOR TESTING !
Posted on Sep 22, 2012
104 degree limit
there is a white button on the back of the heater control board you can hold it down and raise the temp that way, but yes it is not healthy to have the water that hot it is dangerous to your health
Feb 26, 2014 | Pentair Mastertemp Heater
My Spa has a Balboa 500z Top side and control panel. It was running at 104 degrees and then one day it just shut down. The Circ pump won't start up at all and when I first turn on the power, I hear the...
Turn breaker power off. Verify now power to unit with volt meter. Most systems have in line over temp over current to protect circuit board and motor. Also the water level switch must be made to complete interlock condition. Check the heater coil for continuityas it may have opened. Check heater for continuity to each coil set. There is an interlock that is for diagnostics on start up that will prevent unit from starting. Look for any melted wires or components too. Always know and verify breaker settings. Verify your meter with known voltage reading first. Be safe my friend.
Jun 04, 2017 | Balboa Instruments Pool & Spa
Balboa hot tub.. how to turn up the HEAT / TEMP , no owners manual, and does anyone know where I can get one?
You do not have a Balboa Hot Tub. That is the company that made the control panel for it. Id venture to guess it's either a Hawkeye, Barefoot or Master spa if it came with no owners manual. To turn up the heat simply press the Red "up" arrow on the digital control pad. Check out the link below. It's a quick reference guide to what I'm guessing is your top side control.
http://www.hawkeyespas.com/pdf/balboa-504-topside.pdf
Apr 22, 2013 | Garden
Sep 21, 2012 | Pool & Spa
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
My balboa control is set at 104 degrees and continues to heat to 109 degrees and then shuts off. Is there a reset for the heater? Steve
OR
Aug 16, 2010 | Pool & Spa
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
OC hot tub is getting SL error and does not heat. Model is M-09-MOC1545-3. Recently purchased and lost manual. Thanks.
sl means sleep mode and will not heat! try depressing the temp button the either the light button or the jet button usually that will change modes u want st or std mode which means standard. or if u have a mode button try that 1st. or email me a copy of control head to hottubbob2@aol.com for tips! thanks Bob
Oct 17, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Hope that helps,
Ian.
May 24, 2009 | Balboa Instruments Duplex Digital Panel 2...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
