Question about Drills
Channing drills and screw driver bits - Drills
thaurfen
  • 623 Answers
SOURCE: black & decker pivot driver cordless
1.drill hole
2.place rod and anchors
3.screw in
Posted on Aug 23, 2008
  • 12 Answers
SOURCE: Dewalt Drill DC728. Chuck came out of drill body
If you find that the end of the screw inside the chuck is actually broke then you have a gear problem inside your drill. This is actually a very common problem. Sometimes people push too hard on their drills and the gears inside wear out and break. This prevent the motor from wearing out, but, the gears have to be replaced.
If it is the gears and not the chuck. you broke the minimium of the front gear or gears inside your drill. YOU CANNNOT repair gears. they need to be replaced. you may be able to find some off brand gears to work but, you run the risk that they are not as strong as your original ones, or may not be exactly grooved correctly.
so, if replacing your chuck does not work. find replacement gears. IF you cannot find the gears from the manufacturer see about replacing your drill.
If the chuck is still good, keep it. If you buy the same model, keep your old drill for replacement parts, ie, switch, armature, cord, etc.
hope this helps somewhat.
Posted on Jun 11, 2009
tcraignfam
  • 30 Answers
SOURCE: DeWalt cordless drill DW926. I can't get the
Turn your drill speed selector to "1" and put drill direction in reverse. Hold the outer end of the chuck and push the trigger. Should come loose.
Posted on Dec 12, 2009
Testimonial: "Perfect - thank you!"
  • 19 Answers
SOURCE: I have a very old B & D Swivel Drill/Driver
try WD-40 if that doesn't work then it's time to buy a new one. They are cheap these days.
Posted on Oct 22, 2010
  • 827 Answers
SOURCE: HOW DO YOU ATTACH A DRILL BIT TO THIS TOOL? i can
it is not a drill, it is a driver. Unless you change the chuck or add one onto it,. sorry to say., it ain't happennin...
Best regards
Ck
Posted on Mar 06, 2011
Want to install on wood beam, what size drill bit needed for included wood screws
Look at the wood screw threads and hold a drill bit against it. Choose a drill bit that is smaller in diameter than the threads on the screw. Works for any size wood screw.
Mar 11, 2016 | Drills
Best regards
Ck
Mar 06, 2011 | Black & Decker Pivot Plus Cordless...
Can't get bit key to release screw driver to replace with other drill bit.
just use two pairs of grips , one to hold the bit and the other to turn the chuck
Feb 27, 2011 | Black & Decker 3/8" Variable Speed...
Removing centre screw from chuck
Drill a hole in the top of the phillips head screw with a 3/16 th's bit. Don't drill the head of the screw off, just drill deep enough for a torx bit to hold. Take a T-30 torx bit and tap in into the hole you have drilled. Then turn the screw clockwise and it should come out fairly easily.
Mar 26, 2010 | Dewalt Drills
How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Mar 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Was given a drywall screw gun to use, but I need to change the bit to fit smaller star drywall screws. How do I remove and replace this screw bit?
I use a DeWalt and the bit should just pull off like you would a cordless drill/driver. You might need a little persuasion (vice grips or pliers) because of the constant torque placed on it.
Mar 02, 2010 | Drills
Screw in chuck is unknown size
this can be a problem if you have been using reversible drill bits in chuck as they tend to drill out screw head when drill bit jams if this has happened you may have to drill screw and use an easy out remember it will probable be a left hand thread
Aug 25, 2009 | Drills
When you push the trigger turning on the drill it pulsates.
The tool has an 'impuls' function that is very handy for starting bits into hard metal with out walking, or driving or removing screws with damaged heads. The pulse allows the drill bit to penetrate the metal and the screw driver bit to find its' best seat in the screw head.
There is a switch on the rear of the tool. Flip the switch one way to turn on the impuls feature, the other way to turn it off!
Dec 03, 2008 | Metabo BSP15.6PLUS 15.6 Volt Cordless...
Drills Logo
75 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
