Question about Roketa 150cc four Wheeler
How do you hook up the fuel and vacuum lines to fuel pump on a 150cc roketa 4 wheeler 4 stroke
  • 166 Answers
SOURCE: 1992 Jeep 4 wheel drive vacuum line for front axle
there is a vacuum switch on top of the transfer case it applies vacuum when the truck is shifted in to 4 wheel drive . if you connect it to direct vacuum you front axle will be engaged all the time
Posted on Jun 12, 2009
Benimur
  • 6966 Answers
SOURCE: 150CC Roketa Scooter
Hi and welcome to FixYa,
On most versions of Roketa 150cc engines, the choke is automatic and electrically driven..  It is integrated with the carburetor.
Good luck and thank you for asking FixYa.
Posted on Jun 29, 2009
1fastbob
  • 301 Answers
SOURCE: gap for spark plug on a 1985 200e yamaha 3 wheeler
.035" works well for most bikes etc.
See the www.ngksparkplugs.com site and enter your model info and the info is there.
Hope this helps.
Bob
Posted on Nov 07, 2009
nedkelly900
  • 345 Answers
SOURCE: need fuel and vacuum line info
there should only 2 lines from the fuel tap, one for fuel, and the other for vacume, the smaller diameter hose is the vacume, and the larger hose is fuel. fuel hose will go to carby, and the vacume hose to the carby inlet manifold.
Posted on May 24, 2010
rzman
  • 148 Answers
SOURCE: This is an Aprilia Mojito
Hi,,realy does sound like your fuel pump has had it,,did you have an inline filter,from the pump to the carb? anyway you could discard the pump and stick with good old gravity?
Posted on Mar 23, 2011
2008 Roketa MC-75 will not start
Hi, Jerry and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch lever, or kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters
http://www.extremescooters.biz/manuals/roketa_quick_start_guide.pdf
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsprousa.com/?vehicle_type=Scooter&brand=Roketa&brand_model=MC-75-150&srch=2#searcharea
Roketa MC 08 50 User Manual
Jul 04, 2017 | Roketa 150cc cheap Scooters
150cc roketa 4 wheeler 4 stroke. the fuel pump has 4 outlets on it Fuel in, fuel out, vacuum, and vent. What does the vent outlet connect to?
probably nothing as it is a vent tube to allow equalization of pressure on the fuel in the carby
at best it will connect to the air cleaner area at the air filter
Apr 17, 2017 | Cars & Trucks
I had my 06 gy6 roketa 150cc scooter running good,shut it off n now can't get no fire...wont start...new carb,new plug! Any help?
Hi, Jim and the usual suspects are:
1. Fuel tank empty.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
engine cranks spark but still no start
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
MC04A1501
Roketa bali 150 Owner Manual
Mar 29, 2017 | Roketa 150cc cheap Scooters
150cc stator
Chinese Junk I am sorry to say. All made as cheaply as possible.
ROKETA MC-19 STATOR
www.roketapartsdept.com/products/ROKETA_MC_19_STATOR-16828-579.html
  1. Cached
Part# MC-19-150-06-01-09. Roketa MC-19-150 Replacement part. May Fit Other Makes and Models.
MC-19 ENGINE PARTS: Roketa Parts Department
www.roketapartsdept.com/catalog/MC_19_ENGINE_PARTS-579-1.html
  1. Cached
ROKETA MC-19 BREATHER HOSE CONNECT. Product ID ... ROKETA MC-19 ENGINE OUTPUT SHAFT. Product ID ... ROKETA MC-19 STATOR. Product ID ...
Roketa 150: Parts & Accessories ' eBay
www.ebay.com/bhp/roketa-150
  1. Cached
  2. Similar
Find great deals on eBay for Roketa 150 in Scooter Parts. ... MAGNETO STATOR 8 COIL POLE GY6 125cc 150cc SCOOTER ATV GO KART ROKETA TAOTAO ...
Roketa Scooter Parts - All Street Brands - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa
  1. Cached
Roketa MC-16T-150 Scooter Parts. Roketa MC-17-50 (Sicily 50) Scooter Parts. Roketa MC-17-150 (Sicily 150) Scooter Parts. Roketa MC-19-150 Scooter Parts.
Roketa MC-07-150 (Bahama 150) Scooter Parts - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa/roketamc07150
  1. Cached
Items 1 - 6 of 6 - 8 Coil Magneto Stator with 3+2 Wiring Connector for 125cc GY6 152QMI & 150cc GY6 ... 19 99. G07-1459. Medium Weatherproof Cover for Roketa Scooters ... Quality replacement parts for the Roketa MC-07-150 scooter.
Roketa Scooter Parts - Chinese Parts
www.motopartsmax.com > Roketa Parts
  1. Cached
  2. Similar
Roketa Scooter Parts By Type ... Air Filters & Intake (19) · Intake Pipes & Water Pipes · Air Filters · more · Cables (16) ... Roketa MC-19-150. Parts List · MC-20-150. Missing: stators
And TAO TAO
tao tao powermax Google Search
Dec 29, 2016 | Motorcycles
I have a roketa gk28. Which is 150cc -gy6. Im having trouble with wiring the cdi (new racing CDI). Which wire goes where colors are Red,Black,Green,Green,Blue, and Yellow?
Hi, Rusty what you need is a wiring diagram that you can find in the back of your service manual if you can not find the first and best tool you ever bought for your bike, despair not, I have found one for you that costs zero dollars. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day. http://store.oohla.com/storefiles/terminatorscooter//download/accessory/2441/dlt.pdf
Roketa GK 28 KTX 150 User Manual
Roketa Go Kart Parts
Nov 26, 2016 | Roketa GK-D01A 150cc Go Karts with...
Yerf dog GY6 150cc
well you have the wrong pump. and I have only seen 3 nipple pulse pumps... i'd have to see a pic to further help
Sep 22, 2013 | Garden
Roketa 150cc scooter wont start
check for spark. the stater tends to burn up in thows bikes.
Jan 27, 2013 | Motorcycles
Roketa scooter won't start
Hi, Ammoncrosset and the usual suspects are:
1. Fuel tank empty.
cranks but wont start
http://www.roketapartsdept.com/catalog/Scooter_Parts-52-1.html
Mar 19, 2017 | Roketa 50cc Gas Moped Scooter
Webpage error details
100% working IDM fake key block problem
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
Mar 16, 2010 | Microsoft Internet Explorer 8
Jun 29, 2009 | Suzuki VL 800 Volusia Motorcycles
Roketa 150cc four Wheeler Logo
27 people viewed this question
Top Roketa Computers & Internet Experts
David Payne
David Payne
Are you a Roketa Computer and Internet Expert? Answer questions, earn points and help others
