Question about Lexmark Office Equipment & Supplies
Error message on Lexmark S605 says paper jam. There is no paper or jam in the printer. How do I fix?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Turn printer off and turn back on again and see what happens
Posted on Apr 17, 2017
I have a lexmark interact s605 and it wont feed the paper
First, try to unplug the power of the printer for about 30 seconds then plug it back in.
Second, update the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
Third, make sure that the paper is properly placed in the tray and the paper guides is set.
Nov 18, 2012 | Lexmark Interact S605 All-in-One Color...
Lexmark s605 paper jamming
Sounds like an obstruction on the right hand side of the feed mechanism. All-in-ones are a pig to find these - I've had one HP almost completely stripped before I found a chad of plastic stuck in a corner. Nine times out of ten it's a torn corner of the first bit of paper to get chewed jammed in the feed slot.
Apr 06, 2012 | Lexmark Interact S605 All-in-One Color...
My Lexmark X4690 printer keeps telling me there is a paper jam when there is no paper jam. It won't print. How do I solve this?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jan 06, 2011 | Lexmark X3470 All-In-One InkJet Printer
202 printer jammed error message appears, but could not locate
Here's an article in the Lexmark website on Error: "201 Paper Jam" or "202 Paper Jam". This will guide you on where to locate the cause of the problem. Follow the instructions. But if you're having a really hard time locating it or you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jun 28, 2010 | Lexmark C762dn Laser Printer
201.02 paper jam
Please open up the printer take the toner out, please there is a paper jammed in this location, Bring paper out put toner back and power on the printer
Apr 17, 2010 | Lexmark X342n All-In-One Laser Printer
Lexmark x6575 printer error message clear paper jam
Success and relief at last!
Thanks to Dinky on another web site who had the same problem with his Lexmark X6575 printer (a similar printer). The resolution of the problem once I had read Dinky's explanation took less than 30 seconds!
Dinky's exact words on the issue are as follows:
" Dinky commented 5 months ago
Hooray!!!...after lots of hours trying to fix my printers 'Paper Jam' message, even tho' there was no paper jam in my lexmark x6575, but the message refused to go away...I have finally got it to work!!!...
WHAT I DID......
There is a long silver metal bar that the ink cartridges run along. Well just underneath this there is 8 little roller feet that sit on top of another silver/cream roller. Well in between these, in the very centre, you will see a little black plastic nib like thingy...While the machine is turned on, press this little black thingy (best to use a pen or something like, as it's small) and what should happen is the silver/cream roller will make a quick rolling motion....Hey! presto the 'jam message' disappears and the lcdmag-glass_10x10.gif screen should show set-up options (like date, time, ect).
I hope these instructions are clear enough to follow, and I also hope this solves that dreaded 'Paper Jam' message for you all....Good Luck!
Regards, Dinky "
Sep 14, 2009 | Lexmark X6575 All-In-One InkJet Printer
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
PAPER JAM ERROR MESSAGE
your sensor flag in the back is broken or missing
Jun 05, 2008 | Lexmark E342n Laser Printer
799 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
