Question about Staples Office Equipment & Supplies
I have Optima 45 staples in my stapler and if I try to staple it will do it once and then the next one will not staple. It sounds like it did but nothing comes out.
If I open it again it will do the same thing. There is no jam that I can see. What should I do?
    Top Expert:
  • Staples Master
  • 33,322 Answers
Look for a broken piece of staple jamming it.
Posted on Apr 18, 2017
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Jan 10, 2016 | Swingline 87845 Optima ® 40 Desk Stapler
The auto stapling for my Optima 45 won't staple, can it be fixed? It will manual staple, but not auto. Kinda like the motion sensor went out. Any ideas??
Try to take all the staples out then put a small amount of "Two in one oil" as it is very fine oil. Once you have done this wipe off the excess oil if you have a lot spill out wipe with a rag & use the rag to wipe over the underside of one row of staples.
leave overnight & try to use this again with the slightly oiled staples this should remove any oil left then see if this does the trick. (Note I hope you have the correct staples for the machine of course.) Best Wishes Malcolm
Feb 23, 2015 | Swingline Optima Electric Stapler 45 Sheet...
My Optima 45 has stopped stapling. I cleared the area of crimped staples but it won't punch out a staple. What can I do?
There may be a reset button / leaver open it back up have a look around and see if there is any thing like a leaver that needs to be pushed into place for the machine to recognise it has been reset.
Feb 06, 2015 | Swingline Optima 45 Electric Stapler
How do I get this stapler to work when it has the correct staples in it?
leave overnight & try to use this again with the slightly oiled staples this should remove any oil left then see if this does the trick. (Note I hope you have the correct staples for the machine of course.) Best Wishes Malcolm.
Jul 17, 2014 | Swingline Optima Electric Stapler 45 Sheet...
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
Staples will not come out of the stapler.
Did you use Optima brand staples? If not, the stapler will not work correctly. You must use their brand of staples or it will continue jamming, and giving you problems. The staples typically found right next to the Optima staplers in the office supply stores. They come in a rectangular metal box and are labeled Optima staples.
Sep 18, 2013 | Swingline Optima Electric Stapler 45 Sheet...
No staples coming out of machines
The Optima line of staplers do not work without jamming continuously unless you use the Optima brand staples. They can be found in the store next to the Optima staplers in a rectangular silver box, and will solve you problem instantly. There is no other brand of staple that will work in this line (I tried numerous), but once you purchase the Optima staples, problem solved, and you'll love it!
Someone loaded regular staples into our Swingline 45 Optima now it will not work when loaded with the correct staples.
Using the wrong or style ofstaples, overfilling the machine and stapling through too-thick materials can causeOptima to jam. Now follow these steps: 1. Holdthe base down as you lift the top of the Optima stapler to access the stapletray. 2. Removeall the staples from the tray so that you have access to the jammed staple. 3. Turnthe stapler upside down and shake it to clear out staples you can't reach withyour fingers. 4. Gripthe jammed staple with the needle-nose pliers and, while holding the staplersecurely, pull it up. 5. Twistthe staple until it breaks into two pieces if it will not pull straight out.Pull out the two individual pieces. The Optima stapler line bySwingline is designed to be jam-free when Optima premium jam-free staples areused. Using another , style or brand may cause frequent jamming. Hope thiswill help you. Good Luck.
Jul 21, 2011 | Office Equipment & Supplies
How do you open the optima powerease stapler to add more staples?
Push the black half-oval button at the hinge to release the staple cartridge. Extend the staple cartridge from front of the stapler, add staples, push back in.
Jun 25, 2010 | Swingline 87850 Optima PowerEase ? Full...
35 people viewed this question
Top Staples Office Equipment & Supplies Experts
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
