Question about Singer Sewing Machines
I have a singer Athena 2000 , it start working with out me touching the pedal. What can I do?
I
  • Singer Master
  • 665 Answers
Your pedal is an adjustable switch. The pedal stays normally in the off position without pressure being applied by your foot on the pedal. If the spring inside the pedal cannot apply enough pressure to keep it in the off position it is probably due to rust.
1. On the bottom of the pedal their is usually a screw or two to remove.
2. Then their is a slide bracket that must be taken off by sliding it outwards. Their is usually a small spot where a screwdriver can be inserted and twisted.
3. After you remove the bracket locate the spring that applies pressure between the pedal and the base. It is probably rusty. Move the pedal up and down to locate the moving parts. All moving parts (not electrical) must be free from rust. This can be done with carburetor cleaner, tooth brush and a rag or paper towel. Also, blow out with canned air.
4. After cleaning place wd40 on the moving parts (not electrical parts). Move the pedal up and down while doing this.
5. Now replace all parts in the reverse method you took it apart. Give your pedal a try to see if it works any better. Usually this is the amount of repair necessary. If it still is a problem you may need to take it to the repairman.
6 If there is rust on the inside you may want to put more effort into repainting the outside of the pedal. Remember, their are some air holes that must be covered to prevent paint from entering the inside of the pedal.
Posted on Apr 17, 2017
Testimonial: "Did not work, but a red bottom under the machine came out"
    New Friend:
  • 20 Answers
It sounds like your pedal might be stuck in the down position so it thinks your foot is on it. Unplug it, put some oil at the joints where the pedal goes up and down and work it up and down a little to get the oil into the joints. Then plug it in and see if it happens again. If it does, contact Singer customer service because you might have a defective pedal, but I don't think you'll need to after you oil it.
I have a Singer Athena 2000 that stops working randomly. I was able to start it again by turning the switch off and back on, but now it won't start.
Are you still having problems? If so try a different foot pedal. Make sure you use an original foot pedal for your singer. Just an idea.
Oct 28, 2016 | Singer Sewing Machines
How to replace motor belt on singer 2ooo atens
I think you're referring to the Singer Athena 2000, a slant needle, touch and sew machine.
I don't have a service manual for that machine, but on all the machines that I have worked on, there are two belts near the hand wheel, and the tensioner is at the center--the part where both belts come together--and you can adjust it by loosening two Phillips screws.
However, before you attempt something like that, you will need the parts number, and I would purchase the service manual. You can get a part list free and purchase the service manual here. Singer Athena and Touch Tronic
Apr 07, 2015 | Singer Sewing Machines
How do i thread the bobbin on a singer athena 1200 sewing machine
The Athena 1200 and 2000 are "Touch and Sew" slant needle machines. Singer has not made them for many years, but I always loved them, because the bobbin is wound in place--you don't take it out! You can still get a full assortment of presser feet for them; just make sure they're for slant needle machines.
You would be wise to visit the Singer Sewing Machine site and download your user's manual--it's free, and it will show you how to wind the bobbin. There are a series of pictures there as well. There are several steps you need to take, such as raising the presser foot, selecting the blind hem stitch, etc. Sounds complicated, but I owned an Athena 1200, and I can tell you that after the first or second try, you'll find it quite easy.
Incidentally, did you know that it's one of those rare machines that will do a TRUE 1/2" basting stitch! I kept it for years, just for that ability!
Feb 20, 2015 | Singer Sewing Machines
How do I thread a Singer Athena 2000?
The user's manual for the Singer Athena 2000 is a free download from the Singer Sewing Machine site. It will show you how to thread your machine properly. A heads-up, though--the presser foot MUST be UP when you thread ANY machine from ANY manufacturer, going back at least a century!
Jun 21, 2014 | Singer Sewing Machines
Free athena 2000 Manual singer sewing machine
Singer Athena 2000 won't feed properly, feed dog ok, circuit board.
When top is removed there are four adjustments that have red dots, I think I need to adjust one of them. Can you give me advice.
Oct 07, 2011 | Singer 3343 Mechanical Sewing Machine
Trouble shooting a Singer Athena touchtronic 2000 Sewing machine I have a Singer Athena touchtronic 2000 Sewing machine. The light comes on but the needle will not move when you step on the foot pedal. ...
Yes it's true, most parts are not available for this machine anymore. You might try to push the red reset button on the bottom of the machine. Also make sure that the reset button is not being depressed by anything that the machine is sitting on, and that the reset button pushes in and out freelyl.
Apr 27, 2011 | Singer 3116 Simple
How do I fill a bobbin on a Singer 2000 Athena
http://www.singerco.com/accessories/manuals.html
go to this site to obtain the manual.
please mark this answer as a fixya!
Feb 26, 2009 | Singer 3116 Simple
Sewing Machines Logo
29 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
