Question about Carrier Heating & Cooling
Fr error code on window type carrier ac - Carrier Heating & Cooling
    New Friend:
  • 20 Answers
Freon needed.
Posted on Apr 17, 2017
Carrier Ductable 11 Tr ac error code L2 Mean
voltage check 3 amp fuse possible bad motor
Jul 25, 2017 | Carrier Heating & Cooling
How to fix a e1code of split type carrier inverter
Download the service manual and get the fault code to interpret ... probably going to need an AC engineer.
Dec 02, 2016 | Carrier Heating & Cooling
How do I fix an error code 46 on a carrier 4 ton unit
brownout. did you have a power outage? if not loose high voltage wiring somewhere from the panel to the AC unit/ Heat Pump
May 20, 2016 | Carrier Heating & Cooling
I have a carrier window ac error coad 5a flashing for some time ac not on
Find model number and research error codes for that unit. Or try a "hard reset" by turning off breaker for one minute and turning back on, th his may cleat code
Apr 01, 2016 | Carrier Heating & Cooling
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
My 1.5 carrier with remote stops most of the time , indicating fr. Why is it like that .? I have to unplug it again to make it work
http://www.carrier.com.ph/Media/Default/Manuals/icool_manual.pdf
This PDF explains that its a freeze protection safety. Check air filter or freon leak(their words).
So check filter, and also the coil behind the filter may be dirty. Or it may be the fan blade is dirty. Something making the sensor feel a "too cold" temp. And as always it may have a freon leak.
Jun 18, 2015 | Carrier Heating & Cooling
Carrier AC Thermostat displays Error code E4?
E4 indicates an internal memory error. Download the manual and refer to any possible solutions.
May 10, 2015 | Carrier Heating & Cooling
What is the E4 alarm on carrier ac
If it is window type AC the possible problem is thermistor or PCB itself.Kindly check the pics below if the control panel is the same.
Sep 06, 2011 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
337 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
