Question about Filter Heating & Cooling
Free ac serkit filter 3 time blinking light - Filter Heating & Cooling
I have a ge WSSH300GWW front load washer. All of the lights light up, blink 3 times on the panel and the machine beeps 3 times. What could be causing this problem and is it something I can fix myself?
I would check the pump is free to turn and the filter is not blocked, then check water comes in when the solenoid switches on. Is the drum free to move or has the belt broken.
Jan 20, 2017 | GE Washing Machines
When on d AC that clean filter option will gt on and it starts blinkng ...even after the AC ht on This clean filter light will be to off that or how to stop that blinking light?!
Make of t-stat? Normally you can hold down the "clean air filter" button or hold down 2 buttons for 3 seconds to reset the air filter reminder. There should also be a setting in the configuration mode to remove filter reminder. But you would need the installation manual.
May 24, 2015 | Filter Heating & Cooling
Red light keeps blinking
Hello, this is Ava with Think Crucial.
It looks like you may need to change your filters. It is advisable to change filters every 3-6 months for optimal use. When replacing your filters, make sure that the unit is turned off and unplugged from the power. Once filters are replaced, turn on your unit then press and hold the filter check indicator button for 3 seconds. The indicator light will blink 3 times and turn off, and reset the filter change timer.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Aug 24, 2014 | Holmes Products Air Purifiers
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
When using ac power the notebook does nothing and the power light is blinking 3 times then a solid then 3 more times. and then solid again.. can you tell me what the issue is with the notebook.
In which model laptop is this for, however in most cases if there is a blinking light even though if you have it connected to the ac adpater and this happen, it could be that your ac adapter is bad and is not charging your laptop. Does this issue occue when the adapter is unplugged and running on battery only, or both?
Apr 17, 2011 | Computers & Internet
The led light blinks 3 times then pauses then
Pressure switch error code, Check the air filter for blockage, check the vent pipes for blockage or water, make sure the condensate drains are working and that there is no water in the hose(s) that go to the pressure switch(s).
Jan 06, 2010 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
22 people viewed this question
Top Filter Heating & Cooling Experts
Are you a Filter Heating and Cooling Expert? Answer questions, earn points and help others
