Question about Golf
EC go will turn on everything seems operative but nothing happens when you press the gas whether it be forward or reverse
  • 5 Answers
SOURCE: 02 Trailblazer will not go in reverse, but will go in drive
you probably have to reset the ecu!
Posted on Dec 29, 2008
SOURCE: jerky accelerating, late response to gas being pressed
Well for one, make sure you speed up slowly, dont HIT the accelerator. It may also be problems with your fuel filter. After you are stoped fuel stops running through the fuel pump/filter and then when you start going its starts to run through again and it cant keep up so it gets bubbles in it and doesnt move throught the filter easily hence the jerky accelerating. Good Luck
Posted on Apr 24, 2009
  • 308 Answers
SOURCE: when operating duratrax evader ext truck goes forward when told t
Check the servo reversing switch on your transmitter,or swap your motor wires. Hope this helps
Posted on Jul 18, 2009
shocktroop40
  • 155 Answers
SOURCE: ez-go golf cart press accelerator pedal and nothing happens
The first thing I would do is lift the seat and check the battery connections. Those batteries are notorious for corrosion at the terminals. Make sure every connection is clean and solid, as in no loose, corroded or frayed battery cables. Next, if the batteries check out, toggle the run/tow switch, also under the seat to make sure it is fully engaged into the run position, and finally check the forward/reverse lever to make sure the connections are clean and tight.
Posted on Aug 03, 2009
  • 347 Answers
SOURCE: golden companion 1 scooter serial #058632r model
PLEASE VISIT:WWW.ALLDATASHEET.COM ITS FREE.HAVE A NICE DAY, COLIN.
Posted on Mar 14, 2011
What part of the forward and reverse switch is loose on a B&D corded drill Dr560.
What to do next, find your receipt and take it back to where you purchased it and get another one. Make sure the new one works right before you leave the desk of store.
Nov 27, 2017 | Cars & Trucks
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Golf cart starting
There is a custom Golf Cart that looks like a Jeep and is considered an electric club car. If you get a chance there is a show called Barter Kings and one of the shows actually shows one. They are not cheap.
Jul 22, 2012 | Cars & Trucks
Check engine light came on today honda accord v6 2003 at 97k miles. car makes a thump sound when put into reverse hot or cold. sometimes when i turn and accelerate i can reproduce this feeling moving...
Take your car to a mechanic or your local auto parts superstore and have them read/scan the codes for the reason for the check engine light. A good place to start.
Apr 01, 2010 | 2003 Honda Accord
4 wheel drive on 2005 f150 fx series not working. When going forward slowly like going up a hill, all four wheels are pulling. But when I gas on it the back tires start to spin but the front aren't so it...
I had this exact same model. If you're not positive all 4 wheels are under power when going forward slowly, check the 4x4 electronic switch. The fuse might be blown.
Oct 31, 2017 | 2005 Ford F-150
The motorbike starts to backfire and after a while it completely stops as if the battery is overheated
You can trouble shooting it with these methods..
1.check your spark plug.
2. If it is CDI operated,replace it.
3. If it is still Contact Point operated:Check its timing,and if you sure the timing is good but nothing's happened,try to replace the condenser.
Nov 05, 2009 | 2005 Gas Gas EC 450 FSE
Ez-go golf cart press accelerator pedal and nothing happens
Aug 03, 2009 | Sport & Outdoor - Others
I have sigmatel s3 set,the problem is when i connect usb 2 pc nothing happens & their is no web browser in this set plz answer
jst press *### & that switchs to factory mode than u c 5 options press the 5th option,then selct the 2n option gekewei & press ok as 2 times & everything will b allright!!!!!!!!!!!!!
Jun 12, 2009 | S3 MTG EC-3511-S 3.5 INCH SATA TO USB 2.0...
Electric shocks
ive checked all the wiring and nothing is shorting out. is this a common problem? and could it be the lead to the spark plug somehow shorting through a radiator hose that it is touching?I want to keep an eye on this thread.... Same thing happened on my 2002 XC300 a few years ago. I never found any specific cause and the problem seems to have gone away. Funny the two specific times it happened I happened to be almost directly underneath High Voltage power transmission lines. Check your kill switch for shorts. If it is only a single wire unit. That might be the path to your shocking adventures. I have sinced changed my XC into an EC with a new wiring harness and switch gear. So that may be why my problem is gone.,,,
Nov 10, 2008 | 2008 Gas Gas EC 200 Hobby
Electric shocks
Golf Logo
195 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
