Free ac 2.5 ton light blinking 3 time has fult
3 Suggested Answers
  • 116 Answers
SOURCE: What wire size do I run for a 3 1/2 ton AC unit?
it depends on the distance from main power source # 8 if more than 40 feet look at starting amps then google a wire sizing voltage droop chart
Posted on May 09, 2009
  • 47607 Answers
SOURCE: My bluestar split ac 3.ton showing on display light blinking..what is problem
could be a control board either in the inside unit or the outside unit
could be a simple start/run capacitor for the out side unit
best get a technician out to check it out so that you get the correct diagnosis and quote for repair.
Posted on Sep 16, 2015
O general split ac indoor timer light 5 time blinking .what problem
There's a redlight turned on in the inverter of my O General 1.5 ton AC. What might probably be the problem? Please guide.
Jun 02, 2015 | General Heating & Cooling
RED LIGHT BLINKING IN HITACHI ICLEAN AC.. WHAT TO DO?
I was told the same thing that Dennis has posted by the guy who came to service the AC. So I think, it is ok as long as it blinks 9 times in a row and then repeats it after a brief pause.
Jun 08, 2012 | Heating & Cooling
The house in which I live has an electricity line of 2 KW. Will it be sufficient for 1.5 ton AC? Other equipments in the house are: Refrigerator, Fans and tube lights.
Lets calculate your loads :
1. AC 1.5 ton (TR) = 1.5 KW
2. Refrigerator = 0.2 KW ( I guess)
3. Fans = 0.1 KW ( I guess)
4. Lights = 0.2 KW ( I guess)
Total : 2 kW.
Remember that your appliance need more power for starting.
Now you know the answer if all my guess is correct.
For best , You can use multimeter to take measurement on your appliances current draws.
Warm regards, Jay
Apr 25, 2011 | Air Tools & Compressors
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
Misubishi split a c 2 tons green light blinking problems
Please write how many times blinking and with an interval. Depends upon it, we can give solution.
Normally, blinking 5 times means for drain motor malfunctioning. Check drainline, oif blocked clean it. If drain motor not working, replace it.
If blinking 2 times, Indoor room air thermistor defective replace.
Thanks.
Feb 18, 2011 | Mitsubishi MSZ-A15NA Split System Air...
The TV worked fine last night, but today will not power on from either the remote or the front panel. When I remove and reapply AC power by unplugging the cord, the Power/Timer indicator light blinks...
hello am rico, it looks like you have bad lamp, or bad thermal sensor, go get and hold the buttons menu and input or device, it will blink and then pause and then will blink again check the blinking. like 2 pause 3 or 2 pause 2 for codes. if you need more help, feel free to call at anytime. 602-810-7149.
Jan 07, 2011 | Mitsubishi WD-52627 52" Television
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
I have a 95 gmc 350 half ton and my check engine light comes on when I am on the highway and goes off when I drive at lower speeds. I am also getting poor gas mileage.
Most likely a bad egr valve. Take a paper clip. Jump pins A to B at the 12 pin diagnostic connector. (Top right pair wires in the connector - or - Lower left pair of wires depending on orientation) Turn key on. Count the "blinks" of the check engine light. All codes are 2-digit. Short blinks are the ones digit and long blinks are the tens digit. EACH CODE REPEATS 3 TIMES AND THE GOES TO THE NEXT CODE SET. You will get code "12" first..."b l i n k- blink-blink" It will repeat 3 times. I bet the next code will be "32" EGR system malfunction
Nov 22, 2009 | 1995 GMC Sierra
May 08, 2009 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
