Question about Mantis Garden
My mantis tiller is getting gas to the engine but floods out the carb and won't crank back up
    Top Expert:
  • Mantis Master
  • 50,490 Answers
Check for obstruction at the needle seat not controlling the fuel level
Posted on Apr 17, 2017
  • 12 Answers
SOURCE: Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Posted on Mar 21, 2009
SOURCE: flooding carb
the fuel lines were hooked up backwards thanks
Posted on Mar 23, 2009
  • 45 Answers
SOURCE: 2 cycle mantis tiller leaks gas thru the carb. -
if it leaks gas,it can **** air.you have to find out whats leaking and stop it.
Posted on Apr 29, 2009
  • 15 Answers
SOURCE: spring replacement
Replacing the spring on this tiller can be tough. You have to get the tension spring set into the stop and partially wind the tension (by turning the cord pulley) and THEN attach the cord before completing winding the tension spring. It took me about an hour to figure out how much preset of tension was needed before I was able to get it to work. You have to partially preset tension because starting from zero will not fully rewind the cord.
Posted on Jun 03, 2009
  • 15 Answers
SOURCE: when i press gas lever it dies --mantis tiller
Try checking the spark arrestor inside the muffler. They often get clogged and will not allow the exhaust to escape easily. I had this same issue and spent bou coup cash trying to fix the carb and intake side, then when I was going to check the compression, I removed the 3 screws on the muffler cover and 3 more screws on the spark arrestor and found the little screen was clogged. I cleaned it with carb cleaner and ... VOILA...problem solved. I hope this helps. If you call the company they will recommend a carb kit. Try the spark arrestor first (cheaper and easier, too). I hope this helps.
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
I have a Mantis old Mantis tiller, which is working, but leaks gas from the carb after it has been shut down.
you can do this on your own all you need to do is blow it out with a air commpressor
Jan 28, 2013 | Mantis 2-Cycle Tiller
MANTIS tiller 7225-00-02 starter cord won't retract
take the crank rope cover off and in between rope reel and cover there is a wind up spring either its broke or has come out of its slots.
Aug 16, 2012 | Mantis Garden
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
MANTIS TILLER WITH HONDA GX25 ENGINE STARTS FINE BUT WHEN GIVEN THROTTLE DIES OUT. ALSO A LITTLE WHILE BACK OIL WAS COMING OUT OF CARB BUT THIS HAS NOW STOPPED. THIS IS A 4 STROKE ENGINE WITH APPROX 4...
I also have Mantis tiller for 2 years. From the very beginning I had a problems. I was referred by Mantis to the repair store and was charged $90.00 for oil drainage. The second time I was waiting for handle replacement for ~ 1 month. This tiller can't handle even little jobs and the warranty doesn't worth a dime. Maybe I will be more successful using it in my living room . I have an equipment with Briggs and Stratton engines and I never had a problem.
To me Mantis mean big advertisement and waste of money.
Feb 20, 2011 | Honda Hmantis Mantis Garden Tiller with...
What are the carb. jet settings for the Mantis tiller?
When the engine and carb were new, the factory settings were 1 1/4 turns out. As fuel deposits form and things wear, it is normal to need occasional adjustment. If the adjustments need to go more than 2 1/2 turns out, or if the adjustments seem to need constant change, then the carb needs to be overhauled. Here in the USA, many areas use gas that is 10% alcohol. The alcohol effects the soft parts in the carb and will often cause hardening of the diaphragm. If/when you overhaul the carb, also replace the fuel lines and tank grommet.
Good Luck!
Aug 27, 2010 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
MANTIS WILL NOT IDLE
What kind of engine is it ? Does it have a float carburetor or diapram carburetor ?
May 09, 2009 | Mantis 2-Cycle Tiller
Mar 21, 2009 | Mantis 2-Cycle Tiller
Garden Logo
79 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
