Question about Whirlpool Washing Machines
Need to reset my front loading duet whirlpool washer. No water when I started. Now I fixed water problem and machine is not working
  • Official Brand Answer
  • 408 Answers
Hello, we are sorry to hear that you are experiencing a problem with the Washer. To reset the Washer you can unplug the unit or turn off the circuit breaker for 2-3 minutes. If the problem persist we would suggest having a certified technician out to look at the Washer. For further assistance you can send your name, phone number, address, model/serial number and the date on which you purchased the Washer to Whirlpool_Reviews@Whirlpool.com.
Posted on Apr 18, 2017
  • 1073 Answers
SOURCE: Whirlpool duet Front Loading Washer
go over to the end of cycle button and hold in for 3-4 seconds and you have it fixed
Posted on Apr 15, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 7 Answers
SOURCE: Front load washer fills up with water
Jamesbestor,
The water fill selenoid had junk in it holding the valve open or the seat in the valve is damaged.
Turn off the power and water, remove two screws on the back of the machine and remove the lid.
On the back left top corner are the water fill selenoids. Remove these and disassemble by undoing the 6 or 8 screws ( depending upon model ) holding the unit together. Clean and reassemble, it should take care of the problem. If not, replace the selenoid.
Posted on Feb 15, 2009
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Posted on May 17, 2010
  • 662 Answers
SOURCE: Duet GHW9150P Front Load Washer: whirlpool washer says control locked, how can we f...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Posted on May 19, 2010
How do I fix
Try removing the wall plug for 30 seconds and then plug it back in. This will often reset the logic board. If it doesn't, you need a service engineer, as yours is a strange fault.
Apr 09, 2016 | Whirlpool Duet WFW9550 Front Load Washer...
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Whirlpool duet front load washing machine
Have you tried unplugging it, waiting 30 seconds, then plugging it back in to see if it will reset itself? Best of luck
Nov 23, 2013 | Whirlpool Duet GHW9150P Front Load Washer
How do i reset front panel on my whirlpool washer front load duet
Hi
Its a simple procedure to reset the Whirlpool Duet front load. Please press and hold the END OF CYCLE button for 15 seconds to reset. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool duet sport front load washer is fairly new (2008) now it has started dripping water during the cycle under the front of the machine. any suggestions would be helpfull.thank you
check tub boot for any tears in lip that seals to door zippers etc. can tear this.also sometimes water can leak from pump cleanout.you would need to remove bottom panel to check this
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water filling up in Front loading Whirlpool washer
sounds like you have a faulty water valve that does not close when the power is not supplied to the machine.or a problem with the cotrol board supplying power to the valve when the unit is not in use
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LIGHTS ON WON'T TURN ON DL CODE
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
see this fix
Jan 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
106 people viewed this question
Dan Webster
Dan Webster
Sal De
