Question about LG Televison & Video
How can I tell if I need a new LED driver board or an actual light for my LG 32LB560B? No Backlights peeping through the holes in the back. I see something when I use the "flashlight test." THANKS!
I still have sound, but nothing comes up on the screen unless I flash a light on it with the room lights off. To a layman, this looks like I need a "new bulb" because it's "burned out." But online, it looks like I might need an LED Driver board. Is that, the driver board, the more likely scenario? THANKS! ***Edit*** Interestingly enough, not only does it "pass" the "flashlight test," You can actually see a faint image--an image with enough contrast, even when there's no flashlight shining on it. Now I'm even more confused. My one answerer says it's probably the lights strip--we shall see!
    Sergeant:
  • LG Expert
  • 330 Answers
Please replace the LED back lights strips.
Posted on Apr 24, 2017
Led driver on lg led tv. Is the driver bad or the led light strip bad
Only way to find out is to take the panel apart and test the LED strips with a DC power supply
Nov 16, 2017 | LG Televison & Video
I have a 47ln540V LG TV which has black screen. I have done the checks and there are no backlights but an image appears when i shine a flashlight on the screen. Which parts do i need?
TV Parts Universal TV Stands DLP Chips ShopJimmy Go to this page. You will need the back light driver/ballast board. Some models incorporate the driver in the power supply , others are on the main board. In any event the led driver is what you need
Sep 12, 2016 | LG 47LN540V 119.4 cm 47" 1080p LED-LCD TV...
I have a lg 55la6200 tv, is the led driver board and the power board built together as 1 board.....I have no.backlights
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 06, 2016 | LG Televison & Video
Audio is fine. Why did picture suddenly go black?
The board that controls the back light for the screen is called an inverter board. Sometimes, depending on the model , the inverter is combined with the power supply board. Go here to find the parts :www.shopjimmy.com
Feb 02, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
LED Backlights on LG TV?
If audio is OK, the backlight inverter is the part should suspected. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 25, 2015 | LG Televison & Video
I have a LG LED television that has no picture but does have sound. I have narrowed the problem down to 3 circuit boards. I'm trying to find out which one is faulty.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
www.electro-medical.blogspot.com
also check the video
Oct 09, 2015 | LG 47" 5700 Series LED HDTV - 47LN5700
Samsung monitor 2232bw plus backlight fade in black backgrounds scenes
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed as indicated in the attached picture, replace them at once.
If the power supply board is working then it is back light problem, first do a flash light test. If you can see the image in the flash light test, follow the steps how to test back light voltages: https://how-to-repair.org/repair/lg-tv-repair-manual-pdf/lg-led-tv-no-backlights-32ln5300-32ln5310-32ln5700-voltage-test-troub/2pyuXwNkBMA.html and follow the steps how to repair back light LEDs: https://www.youtube.com/watch?v=_poWTEihIJU Fix Led Backlights for TV or Monitor Lg Led Tv No Backlights 32ln5300 32ln5310 32ln5700 Voltage Test Troub Lg... Fix Led Backlights for TV or Monitor
samsung-2033sw-2233sw-ip-43135a-bn4400124s-power-board-dfydxumns33ohqc3bsmt22yf-3-0.jpg
Nov 07, 2013 | Samsung SyncMaster 2233BW 22" LCD Monitor
Televison & Video Logo
