Be profile clock does does keep time correctly. Everything else works fine, 10 years old
  • 201 Answers
SOURCE: Slow clock
Is there a separate battery for the clock memory? If so I would try changing that. Otherwise the clock is probably busted. Digital clocks would not normally loose more than a few seconds a year. If the clocks crystal oscillator broke it may cause this. That could happen if the crystal was not glued down or came loose.
Posted on Jul 07, 2007
SOURCE: microwave panasonic model nn 6358 about 10 years old
Posted on Nov 07, 2008
  • 9098 Answers
SOURCE: GE Profile Advantium 120 Oven not working; less than year old!!
No need to scan now...
We got the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
I'm suspecting the keypad or a door switch or switch mount issue.
Also, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 26, 2008
  • 90 Answers
SOURCE: HP Pavillion DV5000 is about 4 1/2 years old. Battery is dead but has been working fine off ac power. Recently, every time I booted up the computer would work fine for about 10 minutes and then shut d
Sounds like your power supply is starting to fail also. I know it is not a response you want to hear but there ya have it.
Posted on May 28, 2009
SOURCE: trying to set the time on the clock. This device
yorx model 5285 clock radio cassette player , the clock keept blinking and cannot set it.
Posted on Nov 06, 2009
My DSC Wt5500 Alexor Wireless keypad not keeping correct time even after changing batteries. Is there something in the programming I need to do to get it right? Thanks!
I am assuming that the keypad was successfully enrolled? Try to reprogram time. Time should be coming from the main unit and not the keypad itself.
Master Code
24 hour time (ie 2pm= 1400)
Date Format mm/dd/yy
Keypad should confirm successful entry by beeping rapidly three times
press # a couple times to get out of programming
After exiting programming the display should come up within 30 seconds or so displaying the date and time before it goes back to sleep.
Apr 12, 2015 | DSC Wt5500 - Alexor 2-way Wireless Lcd...
How can I fix Springfield Precise Time atomic clock which has correct time on large (minute) hand but is behind several hours on hour hand?
I'm not sure if we have the same clock. Mine has needed batteries for a while, finally picked them up today. Once the batteries were in I had to reset the Zone by pressing and holding "CLK/CAL" button until the time blinks, then release and push the button until you see one single number on there... then set the zone. There is info in the user's guide (I can't find mine) so I kept changing until the time was correct. Now works perfectly.
Jan 23, 2012 | Audio Players & Recorders
How do you correct the daylight savings time problem
If your clock changed to DST late then it's hardwired for the old changeover schedule - and there's no way to reprogram it. All you can do is reset the time manually or change your time zone setting to "fool" the clock into displaying the correct time. Either way, you're going to need to reset the clock as many as four times a year to keep the correct time. The ultimate solution is to replace the clock with one that's set up for the new DST schedule.
May 08, 2010 | Emerson Smartset Clock Radio
Time and date stop when laptop powered off.
it sounds like the cmos batt had the same problem with my desk top once changed cmos batt all was fine .the batt is located on the under side of the laptop you will see some removeable panels just check under these,but be carefull the batt might be soldered in, some are some are not. if soldered in you might want to get a professional to change it as the heat could damage your computer.
hope this helps.
Apr 25, 2010 | Computers & Internet
Oregon Scientific Model 323a--Atomic clock...the atomic clock keeps setting itself to one hour behind what time it actually is in my time zone...I mannually re-set the clock to the correct time...but when...
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
Mar 21, 2010 | Oregon Scientific RM323A Travel Alarm...
My GE Profile is about 10 years old. Everything
cheapest attempt would be replacing temp. sensor....other component if still not functioning,would be the main computer board,which can be very pricey
Nov 27, 2009 | GE Ovens
Hi . My clock radio clock continuously displays
Likely a bad backup battery inside the clock, or a capacitor that is leaking a charge.
Nov 17, 2017 | Lenoxx Electronics CDR-190 Clock Radio
27 people viewed this question
