Question about Garmin GPS
Why does my garmin 1350 keep shutting down after I hit GO after finding a destination??
SOURCE: My Garmin has stopped finding destinations - just says "Searching for Satellite)+
I had the same problem with my Nuvi 310. Found a solution in here that works. Here's a copy of the advice.....note you will need to get in the car and set it for a destination and go. 5-10 mins later the Garmin Nuvi will lose the satellites, but don't adjust it it, leave it on and keep going. Eventually after about an hour it will right itself, pick up the satellites and evrything will be back to normal.
Here's the advice:
happy2surf
Rank: Apprentice
Rating: 81%, 49 votes
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching!
The unit appeared to have "stuck" in this acquiring mode. The following worked for me:
1) open the GPS antenna
2) press the bottom left screen while holding the power button to turn the unit on
3) enter maintenace mode
4) select diagnostics
5) clear error report, do NOT clear any user data
6) restart unit the usual way
My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Posted on Aug 08, 2008
  • 84 Answers
SOURCE: My Garmin keeps shutting off. And when I do get
These units seem to be suffering from a bad connection on the inside of the unit. My wife's did the same thing. There was a connection inside that wasn't making contact. First try cleaning the 4 brass connection tabs on the watch and check your charger to make sure the tabs are raised and not squished. Second try to reset the unit. Hit mode reset and power buttons all at the same time. Hold these for 3 seconds and then release. If these do not work here is what I did. There are no screws holding the unit together. I used a exacto blade to very carefully pry the unit apart along the side seam. It's not easy to do. Be very cautious and gentle. Work the thickness of the blade into the joint to gently wedge apart. You are not trying to remove material! Once apart you will see some fingers that make a connection between the upper and lower part of the unit. This is where the problem was with my wife's 305. I gently raised these tabs to make a better connection, It's been working ever since. I didn't try it before but try pressing very hard on the unit where it says Forerunner 305. The case is very hard so it might not work. But if it powers up when pushing you found your problem. Hope this helps. Here is a link I found on opening a 205 (Same process) http://ctorunner.googlepages.com/dismantleforerunner205 To put the unit back together use Automotive silicon/gasket maker. Use a tooth pick to put a VERY small amount of silicon around the entire seam. Put the two half's together and wrap tightly with electrical tape. Test the unit immediately to see if it powers on and off. If it does not open it back up and raise the small prongs that make the connection from the bottom half to the top half. If any silicon squishes out the sides wipe with water and a rag. Let the unit sit over night. In the morning remove the tape.
Posted on Nov 13, 2009
odiebugs
  • 949 Answers
SOURCE: Garmin nuvi 1350 can't find signal
Fist you should travel around with it, and see if in a different area you get satellites.
It could be where you are at, so this does not mean that in another town or state it won't work.
If you try this and still have problems it could be the unit and you should contact the MFG and send it in for repair.
This is the contact support page I posted below if you need it, its a live link so if you click on it the page will open.
http://www.garmin.com/garmin/cms/cache/offonce/us/support/supportcontact;jsessionid=0D1782886E6A3CF9512F8AEE898B8248
Posted on Feb 12, 2010
  • 4 Answers
SOURCE: My Garmin nuvi 1350 just "shut down" and will not
there is too many problems with this unit, its the worse of all the garmin that was ever made. send it back to the place of purchase
Posted on Sep 20, 2010
  • 587 Answers
SOURCE: Garmin Nuvi 1350 - will
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
  • The device powers on and freezes at the Garmin logo with no trademark or copywrite info displayed on the device which normally shows up below the logo. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and freezes at the Garmin logo and then flashes a white screen briefly. The device then begins a loop of showing the Garmin logo and then flashes the white screen over and over again. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and then freezes or shuts down when displaying the Loading Maps screen.
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
  • Market Name: On the Road
  • Serial Number (listed on the bottom of the device)
  • Question Type: Repair Information
  • Provide a short description of your problem or question: nuvi frozen on Garmin Logo
  • Full Name
  • Contact Phone Number
  • Shipping Address
Posted on Nov 12, 2010
It is working ok but the screen is too bright, without adjust Is it a hardware or software problem? thanks
You should be able to adjust it using Tools - Brightness. If you can't it is more likely a software glitch, as long as all the other touch controls on the screen work.
You can update the software here.
http://www8.garmin.com/support/collection.jsp?product=010-00782-20
You can also do two types of reset.
How to Reset a Garmin 1350 by Kefa Olang, Demand Media Whether you're on a local or national business trip, a Garmin Nuvi 1350 GPS can help you find your way around. However, if the device is not functioning as expected, performing a reset is a troubleshooting step that can solve common problems. A soft reset reboots the GPS's hardware without deleting saved data, but a master reset clears saved data and settings to restore the device to the factory state.
Step 1 Press and hold the "Power" button for a few seconds to reset your Garmin Nuvi 1350 if it's not performing as expected. This soft reset reboots the device's hardware without deleting saved files.
Step 2 Turn off the Garmin Nuvi 1350 if you're still experiencing problems, and then disconnect it from a power outlet, if it's connected to one.
Step 2
Touch and hold the lower-right corner of the screen while powering on the device. Release the power button when the screen turns on, but keep pressing down on the screen. Step 4 Touch "Yes" when the "Do you really want to erase all user data?" message appears on the screen. If the text is in another language other than English, touch the button on the right to confirm your selection.
Step 5 Wait for the GPS to reset automatically, and then follow the on-screen guided prompts to reconfigure it.
Jan 15, 2016 | Garmin nuvi 1350 Car GPS Receiver
Tip
Garmin Nuvi 1350 QuickStart Download
Download Garmin Nuvi 1350 Quickstart Manual
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 Webupdate
Garmin Nuvi 1350 Favorites Backup
Garmin Nuvi 1350 Hard Reset
on May 15, 2010 | GPS
Tip
Download Garmin Nuvi 1350 Manual
Have you lost your Owner's Manual for your Garmin Nuvi 1350 GPS?
Would you like a digital copy of the Garmin Nuvi 1350 Users Guide for easy searching of terms and quick reference?
The Nuvi 1350 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
Why does myGarmin 1350 keep losing external power and shutting down, then restart, sometimes losing current destination info, sometimes not.
Major problem with the Nuvi 13xx series as well as the 11xx, 12xx & 14xx series is a loose/broken USB jack in the back which is preventing power from remaining constant into the unit. This will also prevent the internal battery from being charged. We can repair this issue and reinforce the jack. Please see this link for more information:
Jun 15, 2014 | Garmin nuvi 1350 Car GPS Receiver
FM Traffic Provider database missing
Install and run Garmin's WebUpdater tool as per instructions and try again. If still having trouble come back with comment.
May 15, 2012 | Garmin Nuvi 1350/1350T 1300 1390 3790T...
Tip
Garmin Nuvi 1350 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1350 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Tip
I hope that helps.
on May 15, 2010 | Garmin nuvi 1350 Car GPS Receiver
My Garmin nuvi 1350 just "shut down" and will not power up.
Sep 17, 2010 | Garmin nuvi 1350 Car GPS Receiver
Tip
I hope that helps.
Tip
I hope that helps.
GPS Logo
22 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
