Question about Cameras
Fusion 5 tablet how do i save photos from my camera or sd card o?to Fusion 5 tablet?
  • Cameras Master
  • 5,412 Answers
Connect both to your computer, copy across using Explorer
Posted on Apr 17, 2017
How do you put videos pictures on sd card on a tablet
well assuming your tablet is running android it works very easy to do this , find your sd card in your "file" app then tap it to select it , locate the file names of photos on sd card and tap it , android should pop up a dialog box that asks you if you would like to add this file to tablet ?? answer yes and it will be done , since digital photos can be memory intense you might be only able to save a few to your tablet , Me id leave em on sd card and just view them on tablet
Mar 02, 2017 | Tablets & eReaders
Is there a way to restore deleted photos that were on an SD card
Yes, there is.
GT Recovery for Android Download: www.gtrecovery.net.
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Android - the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
1). Preview & selectively retrieve photos and video lost due to any problem
2). Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
3). Only read and recover the data, no personal info leaking, 100% safe
Jan 13, 2017 | Cameras
I have put 32 gb sd card into excelvan tablet for external storage and its not saving?
Unfortunately, most apps will not load onto an SD card. You'll find that some apps will, if a card is installed, place data there. Mostly the SD Cards are installed for use in storing photos and videos taken by the user with the tablet camera. Newer tablets and smartphones are coming with more and more internal RAM to alleviate the "full" issue, but in most cases, you wither have to give up the new app, or remove one to get another.
Aug 31, 2016 | Tablets & eReaders
How to recover deleted photos from memory card?
Get freeware recovery software on web..DON'T use card any further to avoid putting new images on spots where old ones were deleted.
Then you can recover deleted items.
Jun 06, 2016 | Cameras
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Aug 15, 2014 | Acer Iconia Tablet with 8GB Memory - Steel...
How to save video onto sd card
In the settings of the camera app it should have something called 'default save location' or 'Memory in use' set it to "Ext. SD" card. Most tablets have an internal SD so it is important that you select EXT SD card (external SD card).
If you have already found that setting, and 'Ext SD card' is not listed as an option, you need to format that SD in the tablet itself so it builds the folders it needs. Put it into a PC first though to copy off anything you need because formatting it will delete all data.
Jun 04, 2013 | Mach Speed Trio DROID-7C Android 2.3...
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
How to save photos to an sd card
To save new photos to sd card go to camera-- setting--memory in use( here you have to select memory of sd card ). and a folder name "images" autometicaly becomes in sd card this is the place where photos will save.
Sep 10, 2011 | Cell Phones
Can't access photos on 2 GB SD camera card.
You may try some photo recovery software to rescue the files on your digital camera sd card, here are some for your options.
Photo Recovery (for Windows)
Photo Recovery for Mac
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Mar 22, 2009 | Canon PowerShot A540 Digital Camera
Unable to view pics
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
Dec 17, 2008 | HP Photosmart E327 Digital Camera
Cameras Logo
64 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
