Went to put a load of washing on this morning and was unable to power it up. Has been working perfectly til now???
    New Friend:
  • 20 Answers
Did you check your fuse box? You might have blown a fuse.
Posted on Apr 17, 2017
2 Suggested Answers
  • 2605 Answers
SOURCE: I have a topload machine
Welcome to FixYa.
Based on your description it sounds like a lid switch problem.
Here`s how you can check it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...especially those built in the past 1-2yrs. the model number would distinguish if it applies to your particular model )
Lift the lid, if you observe the underside of the lid there will be a plastic "strike" or "actuator" that goes into a hole when the lid is closed.
Check the hole where the actuator goes into the cabinet and insure you can see a gray oval shaped piece. If so take a small screw-driver, pen/pencil or something small enough to fit thru the small hole and try activating the switch by pushing it down ( machine must be in the spin cycle ). If you don't see it, the switch has likely broken loose and needs to be replaced.
If it start's to function than the switch is not being contacted properly by the actuator on the lid and likely is due to the switch being worn...unless the actuator on the lid is broke, if so there`s the problem.
Make sure the switch is being held in place via the two screws along the side, if they are loose tighten them, if it is broken, it will need to be replaced.
Here`s a helpful link for changing it out,
The lid switch will look like this...
Let me know what you find and if I can assist you further. Thank you for choosing FixYa and good luck.
Macmarkus :)
Posted on Oct 08, 2010
Hoover dyn8164d washing machine, when the last load washed I went to remove the clothes and there was a 'buzzing' coming from the top right area of the machine, I turned it off as usual, and t
Possible that the main power has failed , the power supply of the unit had packed up or there is a serious fault in the controller unit. You need to open the control panel unit to trace this case specially using a multimeter, check for the AC power to the unit and check for the DC to the circuit. If not the panel is a suspect.
Dec 31, 2012 | Hoover Washing Machines
Samsung Anycall screen won't light up
hi i have a problem on samsung shw m110s ..i cannot see any display but its working ..what shoul i do?
pls help
Jul 10, 2012 | Cell Phones
Please help me i lost my washing macine booklet and am unable to get a proper combination i have indesit washing machine wdl 106 i need a perfect combination about temp and all three knobs. cuz right now...
check the internet for a manual for your washer most of the time you can down load them. Put in the name and model number and state you are looking for manual.
Oct 31, 2009 | Indesit WA 125 Front Load Washer
Tub has water in it
sounds like either the discharge line is clogged or the pump is not working, it could be working but getting ready to stop working and doesn't have the power to completly drain the tub, take the hose off the back if the water comes out the hose is clear and it is the pump, if it doesn;t come out then it is clogged
May 30, 2009 | Frigidaire ATF6000ES Front Load Washer
WLAN problems
Try to uninstall and install again ' sorry my english not so good.
Aug 26, 2008 | Acer Aspire 5315 Notebook
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
