Question about Magic Chef Refrigerators
I have a Magic Chef 18EYW-2 fridge. It's cooling but clicking, sometimes loud. There's just a black plastic box next to the compressor. Is this a relay that needs replacing? OK to be noisy?
watugot
  • 290 Answers
SOURCE: We have a Magic Chef MCWC52B
Can you tell where the clicking is coming from?
There is a relay switch on the compressor that will click if it shorts out or if the compressor locks up.
It could also be a thermostat problem.
Thanks/Mike
Posted on Nov 30, 2007
leorcid
  • 281 Answers
SOURCE: noisy refrigerator compressor (?)
This is a compressor problem, and chances are there for this to worsen if not attended promptly.
Posted on Feb 06, 2008
SOURCE: Kneading Blade for Magic Chef CBM 250-2
I found a compatible belt!!! It's a Dayco # 15260, which you can order from partstore.com!!
Posted on Nov 25, 2008
  • 1144 Answers
SOURCE: compressor runs constantly, fridge cools, but not as cold as new
If unit is running constantly, and not nearly as cold as it used to be, most likely a freon leak. Possibly a partially frozen over evap too. If evap is mostly clear except for about 5% of it, most probably a freon leak. Changing controls will probably not fix anything. Need to look into this a little deeper.
Good Luck and hope this gets it done for you.
Posted on May 10, 2009
SOURCE: MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Posted on Aug 04, 2009
Punctured a hole in freezer box, leaked gas. Fridge won't cool anymore. Model #18EYW-2 Magic Chef 1.7 Cu Ft. How can this be fixed?
You will need a service Technician to do this fix .This is not something you can do by yourself unless you have refrigeration experience
May 26, 2017 | Magic Chef Refrigerators
The light may be old, and need repairing, I would try contacting somebody local rather than buying a new one.
Nov 30, 2007 | Magic Chef MCWC30MCG Compact Wine Cooler
I have a 2 year old Magic Chef MCBR445W1 compact refrigerator. When I plug it in it starts and gets good and cold inside. When it reaches the required cold temperature setting it stops running as it s
  • fixdit4real 1 solutionsJun 15, 2011
Ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Mar 23, 2012 | Magic Chef MCBR445W1 Compact Refrigerator
The magic chef wine cooler was clicking now will not get cool .
its your ptc relay.its a very simple fix.to the left of the compressor is a plastic cover with 1 screw.take it off.youll see a small box on top with 1 wire going to it.wiggle it off.pulls straight out left of compressor.go to repairclinic.com..type in part #1206838.its about a $27.00 fix. mines been running fine since.hope this helps
Jan 17, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
Oct 29, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
My Magic Chef Mini Fridge just stopped but the compressor is hot.
ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Aug 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Jun 29, 2009 | Magic Chef MCWC16MCG Wine Cooler
Magic Chief compact fridge motor gets hot but does not cool
Look In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Jan 06, 2009 | Magic Chef MCBR440 Compact Refrigerator
Fridge is not cooling or freezing
can you tell me the model # on the fridge please? the motor is running continuously because it's trying to cool the fridge. it may be a few things, the defrost thermostat, the fan motor itself or the compressor.
Sep 13, 2008 | Magic Chef Refrigerators
Refrigerators Logo
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
