Question about Cub Cadet Garden
129 cub cadet can l adj. pto clutch w/out a gage
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
  • 7 Answers
SOURCE: I need to replace the pto clutch on my cub cadet
best way is to use an impact gun. second way would be to use a pipe wrench on the shaft if theres room. use some liquid wrench to loosen it up too
Posted on Jun 09, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
  • 110 Answers
SOURCE: Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Posted on Nov 01, 2009
  • 6468 Answers
SOURCE: how to replace pto clutch on cub cadet LT1042
before you replace it check the wires on the old on mine broke one inch from the clutch but you only need to remove the center bolt then it pulls off but when you but it back make sure its locked into the part that holds it from turning
Posted on May 11, 2012
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
What does PTO stand for
power take off which drives the belt that runs the mower deck sounds like a dead short in the pto clutch maybe a wire shorting out check for bare wires
1806 cub cadet PTO blows fuse when engaged
check the pto switch..un hook it if thats it then replace
Nov 19, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
I have a cub cadet series 1000 LT 1024 need to replace drive belt, how do i get the pto clutch off?
You donot get PTO of to change the belt. if you want to take the pto
clutch Need to turn the opesit way left
May 31, 2012 | Cub Cadet Garden
Garden Logo
22 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
