Question about Garden
I only get one bar in an area that should get 3 0r 4 bars
  • 3 Answers
SOURCE: sanyo pm 8200 sprint service no signal
Not sure about the bars, but you can go to the settings in the main menue and try to go to roam only. It could be that you r carrier is having a problem with their tower. Your phone, normally, will try to stay on your carriers towers. If you force it to a roaming status, you might get a better signal, but on a roaming network.
j
Posted on Jun 27, 2008
  • 52 Answers
SOURCE: No service
If both of you have the same service provider and her's is working and your's isn't..sounds like your sim or device...hav her put her sim in your device and try to make a call out..if it works we narrowed it down to the sim being the problem. You would then need to replace it.
Posted on Feb 11, 2009
  • 118 Answers
SOURCE: Canon irC3200 Yellow Bar Going Through Prints
try this press asterisk* with head then on the control panel press adjustment and cleaning then go to clean main inside unit run this 2x. try to phocopy white paper only .check wether the yellow bar is still there it could be this a problem of transfer belt cleaning unit .you can clean this by removing the waste bottle and remove one screw and pull out the cleaning unit and cleaned it and return everything hope this will help
Posted on Jul 12, 2009
  • 61 Answers
SOURCE: noise in sway bar area/94 camry 4 cyl
Possibly Inner tie rod end or horizontal lower control arm bushings. Check for tie rod end play with full wehicle weight on tires. Both are often overlooked. Also even a seemingly insignificant amount of looseness in the sway bar bushings can cause a lot of noise, check them closely.
Posted on Sep 27, 2009
bob_computer
  • 3153 Answers
SOURCE: Microsoft Windows XP Professional C:progra~1\mywebs~1\bar\4.bin\m
It may well be some form of virus or spyware.
It may also be that you have too many applications running at once eg. lots of toolbars and instant message typ programs.
It can also happen on graphic intensive applications.
You should rule out nasty stuff first.
MBAM !
for a free one its pretty darned good !
From a CLEAN computer download and put on a flash drive.
Copy to your DESKTOP on the suspec computer.
Run it but dont change any options just use what it offers.
When its done let it clean anything it finds.
Its where I always start with an infected machine.
As for antivirus AVOID Norton or Mcafee but try the AVG FREE version MBAM should clean up without buying
Only continued use would require purchase As for too many applications that would be up to you to decide what you REALLY need and dont. Most toolbars are a waste of both time and space and can hog computers down. Maybe a good clean up is in order ?
It may just be a "leaking application"
These are badly coded programs that dont release memory when they should and just keep taking more to do the same job.
May I suggest you download
"hijackthis"
It is a program that can make a report on what you have running in such a way that you can post that information to certain sites and experts there will look at it.
They will then give you reccomendations as to how you can remove programs or fix some issues that may be upsetting your computer.
Dont post the log here but follow the nstructions and help the program offers to send it to one of the sites it will offer you.
If you understand startup lists you may even be able to spot som things yourself that you dont want to run and disable them from hijack this.
Posted on Sep 28, 2009
Can't find favorites bar
  1. Firefox
    • 1 Launch your Firefox browser.
    • 2 Right-click on a blank area of your browser's search bar. This should cause a menu to pop up.
    • 3 Review the menu's list. You will see an item in the list called "Bookmark Toolbar." If it has been accidentally disabled, it will not have a check mark beside it.
    • 4 Click the "Bookmark Toolbar" option. This will put a check mark beside it and place it back in your browser's top menu.
    Internet Explorer
    • 1 Launch your Internet Explorer browser.
    • 2 Right-click on a blank area of your browser's top menu bar. This should cause a menu to pop up.
    • 3 Review the menu's list. You will see an item in the list called "Favorites Bar." If it has been accidentally disabled, it will not have a check mark beside it.
    • 4 Click the "Favorites Bar" option. This will put a check mark beside it and place it back in your browser's top menu.
    Chrome
    • 1 Launch your Chrome browser.
    • 2 Click on the little wrench icon in the top right corner of your browser's bar. This will bring up a menu.
    • 3 Click "Always show bookmarks bar." This will place it back in your browser's top menu.
Nov 30, 2011 | Dell Inspiron 530s Desktop Computer
The handle bar stem on my sons mongoose is loose. I have tried to tighten the screw that connects to the stem but it doesnt seem to be stopping the bars from being shaky?
Your handle bars are most likely stripped or the mongoose head is stripped or a combination of both. Unscrew the bolt you just tightened and take the handle bars off to inspect the little splined area, if smooth than handle bars need to be replaced. The neck should also have those little lines horizontally this area should not be smooth. You can try to wirebrush the area and out it back together, see if that works or the cheapest thing to replace would be the handle bars. When I was a kid I would pin my handle bars so they would not move cause we did a lot of jumping of our bikes and had a lot of stripped handle bars. Mongoose is a good stem I would lean towards new bars. Good Luck...
Aug 16, 2011 | Cycling
My browser bar or address bar has disappeared on my firefox how do i get it back
Right-click in an area without text or icons directly under the title bar. Click "Navigation Bar" and it will return
I hope this helps & good luck. Please rate my reply. Thank you.
Apr 08, 2011 | Mozilla Firefox
My mozilla firefox window no longer shows menu or navigation bars. How restore?
Hi pbqsf
The Menu bar and the navigation toolbar have been disabled. You can enable it by following the steps below:
1) Open firefox
2) Press the 'Alt' key on keyboard (Pressing this button temporarily brings back the Menu bar)
3) When the Menu bar shows up, right click on an empty area right next to Help as shown in the picture
4) Now select the Menu bar option and the Navigation toolbar.
Now, your Menu bar and Navigation toolbar will be up.
Thank you for using Fixya.
Nov 20, 2010 | Computers & Internet
How do I know when my Garmin is fully charged?
When you start up your Nuvi on the Where to? View Map area you will see by the time on top right corner Green Bars that represent your battery power.... 4 bars full battery
Mar 31, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Noise in sway bar area/94 camry 4 cyl
Possible tranny or engine mount. Check bushings. Check brake pad backing plates (loose), check brake pad movement (add shims), but most likely mounts. you need to torque the engine while an assistant checks for bad mounts.
Aug 31, 2009 | 1994 Toyota Camry
Jul 12, 2009 | Canon Office Equipment & Supplies
Size of sway bar bushings
go to gmpartsdirect.com go to the catalog tab, agree select your car year make etc, front suspension/stabilizer bar components/stabilizer bar/bushing this should get you what you need. This web site has all GMparts at reduced prices. Hope this helps with your problem
Apr 04, 2009 | 2000 Chevrolet Tracker
Sanyo pm 8200 sprint service no signal
j
Jun 24, 2008 | Sanyo PM-8200
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
