Question about Westinghouse Televison & Video
How do i get closed caption on my 50" westinghouse tv?
    Top Expert:
  • Westinghouse Master
  • 44,200 Answers
Closed captioning should be selectable as part of the initial set up procedure.
Posted on Apr 17, 2017
How to get closed captions on tv
To get this feature, you must have its original remote control. a universal remote control might not show it before you.
Aug 19, 2012 | Westinghouse Used Original SK26H590D...
Can't get closed captioning to work on westinghouse 46" 4680 led tv
What is the video source? Some set-top boxes send a closed caption signal that doesn't match the TV's CC interpreter. For those devices, you need to enable the captions on the set-top box.
I know how to enable captions on one particular Dish satellite box. The steps will depend on if your TV is TV1 or TV2 connected to the box. If the TV is TV2, you need to set the box in Single mode (so both TVs are set to the same channel). This is done with the Mode button on the box itself (highlight Yes and click Select using the Dish remote when prompted to go to Single Mode). If the box is in Single Mode, you won't get a prompt but the unit will go to Dual mode. There is a small LED on the box to indicate Single or Dual mode.
Next press Menu on the remote and go to Properties (9). Click Select and then navigate to Closed Captions (6). Click Select. Go to the Closed Caption On/Off line (1) and press the left arrow and then the up/down arrow to set to the captions to On. Press the right arrow and then Select with Done highlighted. Exit the Menu by hitting Cancel repeatedly.
I hope this helps.
Jul 24, 2012 | Westinghouse Televison & Video
When I turn on my tv the closed captioning automatically turns on and I can't turn it off
Hello
After switch ON the TV, and after picture has displayed on the screen with 'closed Caption" window, just press button "CC" on your remote control. For each press, the close caption window will vanish and disappear. OK.
Feb 07, 2012 | Westinghouse SK-32H240S Television
Westinghouse SK-40H590D ATSC LCD TV w/DVD NDW-B Need to find TV setting for Close Caption for the Hearing Impaired for all DVD and VHS I choose to play. How do I download and print a users manual for...
This is a link to both the quick start guide and the full manual for download. http://westinghouse.manuals365.com/HDTV/SK-40H590D.html
I am not sure that this particular function can be set as default however, you may have to set up Closed Captions every time you insert a DVD/VHS.
Jul 18, 2011 | Cameras
Captions wont go off...
sometimes the cable box has the feature as well as the tv. If the tv's captions are off, then hunt in the menu of the cable for the closed captions as well.
Dec 03, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
I have a westinghouse tv and my wife was pushing some buttons on the remote and now i have a black box in the center of my tv. It only allows you to view the image on the outside of the black box. How do I...
Sounds like she turned on one of the Closed Captioning options; not the standard CC style, but the style called Text. Jump into the menus and turn off the Closed Captioning, and all should well
Nov 17, 2009 | Westinghouse Televison & Video
Closed captioning disappeared.
unplug the set for several minutes, then reconnect.
Nov 03, 2009 | Zenith IQB50M90W 50" Rear Projection...
Get the closed caption off my tv
If captions are created by the TV the TV menu allows of/on of captions, however if you are hooked to a converter (sat or cable) these also sometimes create captions. Check the video set up in both places. Might solve your problem.
Nov 29, 2008 | Maxent MX-50X1 50 in. Plasma Television
Close captioning
Hi ckay31,
If your remote is not allowing you to navigate through the menus, you may need to replace the batteries.
If this does not work, in the meantime you should be able to navigate the menus using the menu button on the TV. The Closed Captioning option should display under Channel Settings.
If you are still unable to get your remote to function properly, I recommend you contact Westinghouse Customer Service at (866) 287-5555. You may also view your product's manual at http://www.westinghousedigital.com/pdf/15_User_Manual.pdf
Thank you,
Jason,
Go Ahead. Use Us.
Jun 16, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Closed Caption Option
CHeck on the comcast box- you may have to turn off (POWER) then click (SELECT)select button to get into the user interface , there you may see that closed catptioning is off, turn it on and it should work.
Mar 07, 2008 | LG 37LP1D 37 in. LCD Television
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
