Question about Home
Is there a anti scald device connected to the hot water faucet? When I turn on the hot water faucet, it shuts off as the water warms up.
    Top Expert:
  • Home Master
  • 77,202 Answers
If it is newer faucet then yes there is a device referred to as a cartridge.
Posted on Apr 17, 2017
I have a Glacier Bay shower faucet that is getting increasingly harder to control water temperature out of shower faucet! Water temperature is very hot
check the hot water supply first and if needed adjust if to high and or check your anti scald setting --need to remove the center handle on the mixing valve
How To Adjust Glacier Bay Anti Scald Device Yahoo Video Search Results
Jul 31, 2017 | Glacier Bay Home
Hot water stops flowing intermittently from tub faucet
Newer tub faucets have a anti-scald feature. It normally looks like a piece of plastic dial just above or below The tub handle. It could be that your water set too hott and he scald valve shuts off the hot water only
Sep 04, 2017 | Plumbing
Adjust anti-scald delta B114900
Adjusting the anti scald is pretty simple on this device. Attached is a photo of breakdown for this. Basically, unscrew the labeled part to access a very small black rubber gasket. Remove the black gasket to gain access to the anti scald part. You have have to use needle nose pliers to remove the black gasket but it does come off. Once you have this part off, you will see the two parts (with teeth like a wheel) that will adjust the hot water levels. Remove the part on top and turn the little "handle" clockwise towards "3'oclock" to make the water hotter. The part itself will not allow you to go past "3 oclock" for safety reasons. adjust-anti-scald-delta-b114900-ucghvzot5faznyh4jdqs4e5n-4-0.jpg
Jan 19, 2013 | Delta & Single Handle Shower Faucet
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Oct 09, 2010 | Delta & Single Handle Shower Faucet
How do you adjust temp. water luke warm? This is a single handle. Hot water set at 145.
These type faucets have anti scald dial setting that if you remove the handle you can gain access to it.
Just remove handle and mark or remember where it is and pull it out and reinsert it about 1/4 turn counter clockwise.
It has got marks on it and looks like a little gear.
May 19, 2010 | Danze & Single Handle Tub And Shower...
No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
Apr 01, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
How to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Feb 10, 2010 | American Standard Bath Faucet Ceramix...
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Have a combi boiler and the hot water from my taps are running cold to luke warm. My British Gas engineer has told me it is nothing to do with the boiler but is caused by a faulty thermostat cartridge in...
Modern shower valves have an "anti scald device" in them to prevent scalding from to hot water.
They come preset at 120 degrees.
Sometimes they can start to malfunction and all you get is warm, not hot water, they can also be intermittent.
This will only effect the shower valve though, not the other faucets.
Dec 06, 2008 | Heating & Cooling
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
