Question about Pro Computers & Internet
Setting up mcaire using cat5 cable from router
Have cat5 connected from router to McAire have cat5 connected from MacBook Pro to router
osborne382
  • 306 Answers
SOURCE: Cat5e to RJ11
You wont be able to....You need another NIC...you can Pick one up at Circuit city of best buy for about 10 to 15 bucks.
Posted on Nov 10, 2007
ceezer
  • 20 Answers
SOURCE: Macbook airport
you should try a software update first along with a PRAM and SMC update (hold the power button down when the computer is off for 15 seconds-it will beep. immediately after that hold down the Apple, option, P and R keys simultaneously until the computer reboots and chimes 3 times)
Posted on Jun 10, 2008
kakee
  • 1269 Answers
SOURCE: macbook pro only laptop in house that drops wireless connection
This sounds like an Intermittent Wireless connection problem. This is caused by cordless phones with 2.4GHz frequency. What you can do is change the Wireless Channel of your router to a different frequency/channel like channel 11, 1 or 9. Also you can try to relocate the base of your cordless phone away from the router or to a different room. In addition, you can try positioning the router to higher places like on top of cabinet or mount it on the wall..
Posted on Nov 30, 2008
cnavarro
  • 2460 Answers
SOURCE: How to get wi fi at home for itouch?
Your better bet is a wireless access point. It plugs into your router and can be configured to be transparent to the network so that any IP address you get for your wireless device comes from the original router (better for networking).
At the blinkingly fast speeds of your Wireless internet, "N" is a waste. Get the "G". Here's a link to the product I would use...it runs about $50. http://www.tplink.com/products/product_des.asp?id=116
Carl
Posted on Feb 27, 2009
  • 10406 Answers
SOURCE: Is there a way to
The speakers should directly connect to the "line-out" socket on your Macbook computer, without any need for adapters.
I have _never_ seen a wireless router that had _any_ "audio" capability -- what you're asking for seems to be unreasonable.
Any "Dollar Store" or the "big-box" stores (such as Best Buy, Office Depot, Staples, Future Shop, Wal-Mart) should have adapter-cables.
Posted on Aug 19, 2010
Hello friends How can I set up my computer win7 to the Konica minulta printer by network cable cat5 please answer very detail.Many thanks.
First, you CAN'T connect a CAT5 cable directly from your PC to the Printer. That won't work. Both have to be connected with their own CAT5 cables through a hub or router on your network. The router gives them separate IP (network) addresses so they can talk to each other.
You may need to set up the printer through a direct USB connection to your computer. Once the networking options are set, IF it's an Ethernet-capable printer you may be able to connect that way.
Jan 20, 2018 | Konica Minolta Office Equipment & Supplies
Crossover cable asus eeepc
I would think you can do that through a network router or you can make a crossover cat5 cable by switching wires 1 & 2, and 3 & 6 of the plug on one end.
Mar 13, 2013 | Computers & Internet
Need to scan from hp 4345mfp to macbook pro
This site shows that as of October 2017, the 4345mfp doesn't have software available to scan from the printer. You would think that a file physically sent to a Mac from the device should be seen, but apparently that isn't the case.
https://support.apple.com/en-us/HT201465
"You can share your USB connected scanner with other Macs on your home network." So you might go that route; connect to the Mac and share the printer to other devices.
https://support.apple.com/en-us/HT204790
Feb 20, 2018 | Office Equipment & Supplies
Hi. I am running RoadRunner as my internet provider on this modem. It will connected wired with my Ethernet cable to my MacBook Pro 15, but I am suddenly unable to connect wirelessly using my Apple Time...
Welcome to Fixya
You dont need a CD or driver to connect to time capsule. All you need to do is to have you MACbook detect the Time capsuple. Open AirPort Utility, select Time Capsule, and click Continue. Enter the password of the time capsule if incase you secured the router.
Thank you for using Fixya!
May 31, 2011 | Computers & Internet
What type of cable do I need to connect my macBook Pro to a Dell DLP MP1200?
You should be able to use a USB - 4 pin mini-DIN cable with this projector.
Mar 01, 2011 | Computers & Internet
My net speed get very slow
If you are talking about about your speed while connected to the wireless, I do believe this is a 801.11b, which means it is a slower router (for wireless) and only goes up to 11Mbps. If you think you are getting even slower speed than that, log in to it, go to the wireless setting tab and find the setting for the connection speed. make sure its set to use the full 11Mbps! (sometimes is can be set to only 1-3 or 3-5Mbps).
If you are talking about the speed while connected via hard wire (eithernet cable), log in to your router and make sure that the wired speed is set to the highest value (I believe this one goes to 100Mbps full-duplex) and also make sure that the cable you are using is at least a CAT5 or above (CAT5. CAT5E, CAT6). A CAT3 ethernet cable will not go up to the 100mpbs! (this is printed on the wire).. also make sure that the port on your computer also goes up to 100mbps!
hope this helps!
Jan 16, 2011 | D-Link DI 514 Wireless Router (DI-514)
Integrating a mac network
I have an iMac and Canon MP970 printer connected to the router via CAT5 cable and a MacBook Pro that uses the n-protocol of the WLAN. Both work fine and I did not install anything special...
There is really nothing to 'set-up'... What problems are you afraid to experience?
Dec 27, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I have a desktop and a laptop (new for xmas) and I want to set up the laptop to the wireless-N Router Model WRT160N. I am set up with internet through a bundle system through our television. Do I plug the...
first a couple of things.
if your router has wireless support your laptop (if new) should have a wireless adapter built in, so basically your destop computer can be wirely plugged into the router and your laptop shoud "connect wirelessly" to your adapter
so this is how your set up should look like
desktop
--cable-- = - cablemodem - = linksys router = ----- wire----- desktop
laptop
--cable-- = - cablemodem - = linksys router = ))wireless))) laptop
you need read up a bit, here are some links that will have info you need
manual for wireless configuration (select the proper revision for your router and check user manual)
configure wireless network for vista
read up and if you have any questions post back.
hope that helps.
Dec 26, 2009 | Computers & Internet
PC laptop will connect to the internet MacBook Pro Won't
Check your router's IP address from the Compaq machine. Get a command prompt and type ipconfig .all
Then wright down the IP settings.
Check the IP settings of the Macbook Pro. Adjust settings. You can give a Static IP also. If needed. But you have to set the default gateway -Enter previouse IP settings for those.
Check ur Wi-Fi settings also.
If this is helpful to u please rate
Thanks
Wish U Luck
Jun 16, 2009 | NetGear RangeMax WPN824 Router
Apple AirPort cannot get IP address from cable modem using DHCP
go to applications,utilities and go to airport set up and check the settings, it could need the DHCP setting up or the old settings deleted
May 24, 2009 | Apple AirPort Extreme Router
Computers & Internet Logo
Top Pro Computers & Internet Experts
Vernon Taylor
tosin_christ
Are you a Pro Computer and Internet Expert? Answer questions, earn points and help others
