Question about Panasonic Audio Players & Recorders
I have a Panasonic SA-PT1051 surround sound system that brings up code F61 when I turn it on and then immediately shuts off. What is wrong and How do I resolve this issue?
  • 4 Answers
SOURCE: F61 error in my SA-AK25 Panasonic Audio System
CHANGE STK --------IC
Posted on Mar 27, 2008
  • 4234 Answers
SOURCE: Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
Posted on May 15, 2008
sleepy_user
  • 140 Answers
SOURCE: I have an issue with Panasonic SA-HT545 Surround sound system
I have a similar unit about 18 months old...just wouldn't start and gave me the F61 code. I opened it up and found that the fan on the back was not running properly...the fan's circuit feeds back info to the cpu that it is running...when not it shuts the system down. I powered the fan externally with a 20v power source and ran it for a while off the red and black wires (the yellow wire must be the feedback)and re-installed it. All is working fine...but I'll go out and buy a new FAN.
Posted on Jan 29, 2009
heavyice
  • 374 Answers
SOURCE: panasonic surround sound system model # sa-ht95
Error code ' F61 ' on most Panasonic models indicate that the built-in diagnostics has sensed a fault at the output stage. This would normally refer to a failed output amplifier IC (?P/N RSN704D66P?). In some instances, the fault could also be triggered by:
  • strands of Speaker wires inadvertently touching each other;
  • faulty speakers;
  • failed Cooling Fan of the output IC.
Options then are:
  • consider a DIY (do-it-yourself) repair only if familiar with electronic components & circuitry, use of a DVM/VOM and a soldering iron. Access to a Service manual would be an advanatge;
  • seek the services of an authorized service center specially if the unit is still under warranty;
  • consider other options based on downtime, cost of repair, parts of availability, age of unit and prices of comparable but newer models.
Good luck
Posted on Mar 06, 2010
  • 189 Answers
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
Posted on May 12, 2010
Error Code F61. Do I need a new fan?
it is fault of cooling system, and sound output error, if fan is disconnected or not running F61 comes on screen then nothing happends, power sound ic is the main cause of the device, not only cleaning works, may need to change the the power sound out put ic.
Nov 02, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
I have the f61 code on a panasonic surround sound. should both fans spin on power up?
Pretty sure both fans should turn. If the unit senses the fan not turning, it will shut down as you are describing. Try taking the label off of the fan so you can see the bearing, and put a couple drops of oil in there. This sometimes get them to turn freely again.
Dec 28, 2012 | Peerless "Panasonic Sc-Ht990 Home...
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
I have an issue with Panasonic SA-HT545 Surround sound system and it keeps coming up with f61 problem and its not working now
Jan 29, 2009 | Audio Players & Recorders
Panasonic SA-HT940
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
Suttound sound
not just this code f61 but now it is on and center and surround speakers don'ts work
Mar 12, 2008 | Panasonic SC-HT720 System
F61 code
yes i did see this code F61  but turned off and back on and the surround and center speakers still don't work
Jan 06, 2008 | Panasonic SC-HT720 System
24 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
