Question about PfaFF Sewing Machines
I have a pfaff 2170 was serviced recently used 4 hours and now when sewing a seam on the bobbin side the thread gets all tangled up and then it locks up. Is this a tension adjustment?
    Top Expert:
  • PfaFF Master
  • 42,218 Answers
It indicates that the needle thread tension is not tight enough
Posted on Apr 17, 2017
  • PfaFF Master
  • 9,312 Answers
It sounds like you are getting "thread nesting" or what I call "thread barfs."
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Check that the thread path is correct.
Set the top tension to the midway point (and, if needed, tweak this because every machine is slightly different and subject to wear).
If you continue to have problems, you should probably take it back where it was serviced and have them look at it again.
P.S.--try installing a brand new needle and see if that helps. And, try a different brand of thread--AVOID old or bargain bin thread!
This will help with tension issues:
http://www.threadsmagazine.com/item/4302/understanding-thread-tension/page/all
Y does my top thread pick up on hook and when it catches bobbin thread it gets tangled up on top of bobbin
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? v
May 21, 2015 | Sewing Machines
Thread jamming in bobbin when i use walking foot
Had a similar problem with our Pfaff. Needed a replacement cam. broken gear.
May 06, 2014 | Elna 2007 Mechanical Sewing Machine
Pfaff tiptronic 2020 locking up/cutting bobbin thread
try changing the needle
when sewing a project-- the needle & fabric & thread must be compatable
check to see if there is any burrs on the needle plate or on the bobbin case
always make sure every thread guide is used
make sure the bobbin is inserted correctly in the bobbin case
Mar 31, 2012 | Sewing Machines
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
My pfaff 2170 says "main motor blocked" how can I fix this?
It happened to me... Check the bobbin and thread in the shaft ... Pull out the bobbin and remove all thread from the shaft. Pull out any thread remains with the tweezers. Check the feeder dogs and the needle (see Owner's Manual 2:7). Re-insert the bobbin (see Owner's Manual 2:12).Make sure that you use a good quality thread and set everything up correctly. Good luck!
Sep 09, 2010 | PfaFF Creative 7570
Needle's thread gets tangled in bobbin
First, open the needle plate and make sure the bobbin area is clean and free of lint and thread.
Check the needle to make sure it is not bent and is properly inserted into the holder - usually with the flat side facing to the back of the machine.
Refer to your manual for bobbin insertion to be sure the thread is feeding from the bobbin in the correct direction and through the proper guides.
Always thread a sewing machine with the presser foot up. This opens the tension control and allows the thread to properly enter.
When the foot is down, the tension control closes to the sewing setting and if the thread is not in place, there is no tension on the thread and it gets loopy.
After threading, lower and raise the needle while holding onto the thread tail. This will pull the bobbin thread up through the needle plate. Take hold of both threads and take them under the presser foot and to the back of the machine.
Hand walk the first stitch when sewing and this should keep the top and bottom thread from tangling.
When stopping to change the position of the fabric (turning a corner, sewing a curved seam for example), do so with the needle down into the fabric. This not only anchors the fabric so it does not slip, but prevents mis-stitching.
If you are doing everything according to the manual and are still having a problem, the machine may need to be professionally serviced.
Feb 23, 2010 | Elna 1010
My sewing machine will not pick up the bobbin thread. It sounds normal and pulls the fabric through, but the threads do not intertwine. I had been having problems with the bottom thread clogging and...
when the needle pulls the fabric into the feed dog you dont have enough fabric behund the neelde when you srart, and the fabric gets caught in the feed and the bobbin case underneath clean it out anf change the needle they often get bent after they get tangled in the thread and fabric
Dec 10, 2009 | Bernina Sewing Machines
The bobbin is loaded but when i go to use it I get a tangled mess of thread underneath my fabric
Usual cause is bobbin threaded wrong or more commonly improper tension of the upper thread. Sometimes the bobbin tension may be wrong due to thread size change etc.
Sep 04, 2009 | PfaFF Sewing Machines
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
