Question about The Health & Beauty
I brought a mishto cb330 car battery charger its not charging my car battery its been on charge all nite the green indicator on the battery has not lit up yet or am i using it wrong.
    Top Expert:
  • The Master
  • 46,775 Answers
Possibly
the charger leads ( red and black) have to be connect correctly
red to the positive+ terminal of the battery and black to the negative - to the battery
if they were wrong , you may have to replace a fuse in the battery charger
Posted on Apr 17, 2017
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
2008 yamaha R6 YZF: i have to use jumper cables everytime to start it everytime. i brought battery to be tested. they said battery was good, and recomended a charger. i purchased charger and charged over...
It sounds like the battery you are using doesn't supply enough power to start the bike. Using jumper cables starts the bike because of the additional power you are supplying it. Make sure you are using the correct battery. Check to see if there is a more powerful battery available for purchase.
You have many options.
-bring it to a dealership and have them charge / test it.
-buy a charger yourself and charge it.
-buy a trickle charger and charge it yourself.
-buy a brand new battery and not worry about it for a couple years
Feb 17, 2011 | Yamaha YZF-R6 Motorcycles
I have a jazzy power chair and when you turn it on all the lights come on for about 3 seconds then they go off and all you have is the red lights. we live in alaska so nobody around here to take it to
John Do the red lights blink or steady? this indication on the joystick usually means low batteries. Now this could be caused by bad batteries or a bad charger. On the jazzy if you have an on-board charger the light on the charger will come on green when the batteries are fully charged. If you can look under the rear of the chair you will see the charger and can tell if the light is green with the charger still plugged in after charging overnite. If the light is not lit then you probably have a bad charger. If you have a digital volt meter put it on dc volts 200 volt scale and plug the leads into the two outter charger port holes located under the front of the joystick. Your battery level should read 24-26 volts after charging all nite and with the charger plugged in up to 30 volts if there is no change in the voltage from charger plugged in and not plugged in then the charger is bad. You can then look to purchase an off-board charger that plugs into the joystick charger port to charge your batteries. If your battery readings are lower than 21 volts even after trying the new charger then you will have to replace the batteries. You might try to find someone in the local area that has an off-board charger you could borrow to see if you can get the batteries to charge. This will help you find out if the batteries need replacing. Hope this helps
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
Yellow & Green lights stay on,battery will not charge
I hooked a 12 volt car battery charger to the battery for about two min. Then I put it in it's own charger,the yellow & green lights came on for about 5 sec. then the red light came on . About 30 min. later the green light came on and the battery is fine.
Jun 22, 2009 | Ryobi Multi-Volt Battery Charger
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
BATTERY CHARGER RADIO SHACK DELUXE 10 CELL
I would go to Radio Shack and have them explain the proper charging procedure as well as inquire about the red and green lights as not all chargers go green when fully charged-Normally red indicates a charging action and if a charger has no fully charged light, then a required charge time period is noted in the instructions. Batteries can be ruined by over charging!
Jan 03, 2008 | Energizer Rechargable Battery with Charger
Health & Beauty Logo
Top The Health & Beauty Experts
Motshidisimary
Motshidisimary
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
