Question about HP Office Equipment & Supplies
My HP pinter makes a grinding noise when printing, I switched the color cartridge and the problem went away for a while but now it is starting to make the same noise.
  • 31 Answers
Clean Both the colour cartridges and black cartridge as well
Posted on Jul 24, 2009
    New Friend:
It's a bad lot. I talked to HP they are aware of the problem and have sent my 3rd replacement which fixed the issue
Posted on Dec 08, 2012
  • sdsteven
    sdsteven Dec 08, 2012
HP C310A grinding noise
Grinding noise is unusual. Check for the following ...
> Place the printer on an even surface.
> You may remove the ink cartridges and install them back.
If issue still persists, please call HP Tech Support as the printer requires a service.
If you are from USA and the printer is Out of warranty, then you may be provided an option to Trade in.
If issue still persists, please call HP Tech Support for further assistance.
If you are in US , the toll free # is 1-800-474-6836 .
If you are not in US , then log on to www.hp.com , at bottom-left corner there is a world map icon, click on it and then select the region you belong to, which would then provide support options for you for that region.
Apr 01, 2013 | HEWLETT-PACKARD C310a All-In-One InkJet...
My Laserjet 5SI printer has been jamming a lot lately and now it's making a grinding noise. Should I replace the cartridge or what?
Fusers generally make grinding noises more than cartridges do. If your paper jams are in the fuser area, check the fuser first.
When you open the left side door of the printer, the fuser is installed on a shelf near the top of the cavity. To remove the fuser, grasp the left and right blue fuser release handles and rotate them to the straight up and down (vertical position. Then lift up on the fuser and remove it from the printer.
Take a close look a the at the gear located on the top left corner of the fuser - does it have broken/ bent teet or is it loose on its mounting shaft? If so, that's probably causing both the paper lams and the grinding.
Also look in the printer directly under where this gear would be if the fuser were inserted in the pinter. Do tou see a build-up of fine particles the same color as the fuser gear. If you do that's further proof the the gear is bad.
You can but a replacement fuser at several places - check out www.printerworks.com & you can get one on an exchange basis.
Oct 27, 2010 | HP LaserJet 5si Printer
MY HP laserject P3005 printer makes alot of grinding noise but prints fine,is there anything i can do
Hi lexdalex,
Test the cartridge, if you have an old cartridge then insert the cartridge and try running a test print. If the grinding noise is gone, then it is the cleaning blade on the cartridge.
Al
Aug 02, 2010 | Office Equipment & Supplies
Hp deskjet 882c printer carriage is stuck
Hi first of all you need to make sure that everything is in good shape on the carriage and the cartridge holder,
also check if you have any broken plastic pieces in the printer.
you mentioned the reset a well
was it a partial or a semi full reset
another thing which we can try is
1>take out both the cartridges
2> unplug the power cable while the printer is on
3>press the power button for 30 sec to remove the static
3>replug the power
now let the printer lights blink prompting you to put the cartridges
4>put the black cartridge first
some Hp printers work on single cartridges as well.
5>see if you hear the same grinding noise again
6>try cleaning the rollers with a little damp lint free cloth
7>try putting the color cartridge
make sure that the cartridges snap inside properly.
8>see if the problem persists
Jun 15, 2009 | HP DeskJet 882c InkJet Printer
Color Laserjet 2550 Loud Noise when starting up and printing
Remove toner cartirdge and check gears on cart as well as all of the gears you can see inside the unit for any signs of wear. You may also need to remove the fuser assembly and perform the same task with the gears back there. MAKE SURE THE POWER HAS BEEN TURNED OFF AND THE PRINTER UNPLUGGED FOR AT LEAST 30 MINUTES BEFORE ATTEMPTING TO TOUCH THE FUSER. IT WILL BE HOT!!! Most frequently these kinds of noises from the printer are due to gears slipping. Sometimes simply reseating the fuser assembly or toner cartridge will fix it. If there appears to be excessive wear on any of the gears, you will need to replace them.
May 29, 2009 | HP Color LaserJet 2550n printer + HP Color...
HP Deskjet 1320 printer makes grinding noise and stalls before it prints
I think the noise is normal for hp deskjet. When starting up, the printer read the head existence, and do cleaning. is it the first replacement cartridge? Disable ink status monitor.
May 29, 2009 | HP Office Equipment & Supplies
Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Hp psc 2110 incorrect ink cartridge message.
Hi plabonne,
I hopped out to HP's support site for stats on your cartridge and found some info at this link:
http://www.shopping.hp.com/webapp/shopping/supplies_model.do?product_code=C8648A&jumpid=oc_R1002_USENC-002_HP%20PSC%202110%20All-in-One%20Printer&lang=en&cc=us
are you using an HP 57 Tri-color cartridge? HP printers work best with HP cartridges and often have problems with refilled cartridges. the grinding noise you're hearing makes me wonder if the cartridge isn't seated all the way in its little carridge (the plastic part that holds the cartridge). have you had a chance to slip teh cartridge back out and try gently slipping it back in again?
here's another link to try for info for this model of printer (HP's support site), with specifics about your error message about half way down the page:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu05206&dlc=en&product=79488
hope this helps!
-JW50
Nov 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
HP Deskjet 6980
Take a look to see if the printer Cartridge Carriage belt is hung up
or something else is jambed.
Sep 12, 2007 | HP PSC 2110 Color Printer
351 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
