Question about Health & Beauty
Joystick error code - Health & Beauty
Can any one tell my the solution of error code #35 ,#37 and #36 of quantum pride 610?
This indicates a joystick problem. Check the wiring connection and the joystick neutral. There may be a mechanical or electrical problem with the joystick. Test by swapping out the bad joystick with a good one. Hope this helps.
May 11, 2016 | Pride Health & Beauty
How do I check power module and joystick module connections and wiring on my wheelchair?
hi Kathy, sadly there isn't a easy way to do this and you really need someone skilled in working with the powerchairs. This can be a joystick fault however make sure all connections are a tight fit ...
If you're based in the UK please give me a ring as I carry out free testing ...
Regards
Rob.
Feb 16, 2016 | Pride Jazzy Select Elite
Permobil C 300 joystick showing joystick error and code 0E00 how to correct?
0E00 Joystick Error Joystick Error Right System fault Joystick Error
that is the info from permobil documents, it may be an error of the right motor / wiring "check all connections, unplug and plug in again all connectors, if still persists then it would seem to be an error with the controller its self, this maybe the pcb or the joystick its self, some times if you give the joystick a good workout (moving it to its limits over and over again for a couple of mins and then turn on and see if error clears) if that fails then it looks like a new joystick or the whole controller might need replacing, if you know some one with the same controller on there chair see if they will let you plug it in to your chair just to confirm it is that.
hope that helps, and if so please click "Helpful" to let others know
have a great xmas all
Dec 01, 2014 | Health & Beauty
Yellow wrench light ctm hs 1000
Usually a generic 'trouble' indicator. Can you read out the error codes or fault log?
Aug 20, 2014 | Health & Beauty
Error code of 7
Error 7 is most often is a problem in the joystick. Unless you have a large heavy knob you have put on the joystick and can remove and turn the chair off and back on it will need to have a diagnostic test done on it, by a service company, to see if it can be reprogrammed or need to be replaced.
Jun 27, 2014 | Invacare Pronto M51 Power Wheelchair
Flashing wrench 9 times
Lester - so many issues. Take it to a dealer.
9-Flashes means comm fault - check joystick wiring harness.
Nov 01, 2013 | Electric Mobility Invacare Pronto M41...
Rebuilt motor installed in Pronto m50 power chair, now joystick forward, takes chair to right, joystick right takes chair forward, joystick to left, taks chair back, joystick back takes chair left, HELP
u need a programer o reset that joystick to the new motor,so call the dealer have them send out a qualified tech with a programer to check error codes and reprogram
Sep 26, 2013 | Health & Beauty
It just flashes all the time when it's on and won't move. pride 7. what error do you get when the joystick goes bad? can I replace the joystick myself?
These are called VSI error lights. The VSI is the fancy name for your electronic controller. [Basically the joystick :) ] The number of times they are flashing, gives you the codes of the problem. The system locks until it is sorted to prevent injury. Follow the link below for the User Manual for your model. First check page 37 to see if it isn't just locked, then page 38 for code meanings. If its flashing lots, most of those high numbered ones are just a case of checking things are all plugged in tight.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Jazzy%201103%20Ultra%20Owner%27s%20Manual.pdf
Hope this helps.
Apr 29, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Pride mobility Jet 3 Ultra Power Chair 7 flashing lights. joystick error. how do i fix ? Three red LEDs Four yellow LEDs
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. smithrmrm70@hotmail.com
Sep 06, 2009 | Jet 3 Ultra Power Chair
Health & Beauty Logo
24 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
