Question about Kenmore Washing Machines
Kenmore elite washer model #42198900. OE code . Replace already the water pump with brand new but still OE comes up on the rinse cycle.
    Top Expert:
  • Kenmore Master
  • 75,066 Answers
I suspect you are having an issue with the an electrical connection to the pump or the pump control board..
Posted on Apr 17, 2017
I have a kenmore elite HE3 washer. I was getting the sud error and then eventually F02. I cleaned out all the drain lines and pump filter trap and this did not help. I've now replaced the pump
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Nov 24, 2012 | Kenmore Elite HE5t Washer
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
F02 Code -
The following link explains the "F02" error on a Kenmore Elite:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
More commonly, you have a clog in the drain pump. I would recommend starting there first. The link I provided gives a follow-on link that describes how to clean out the drain pump of debris. I would also recommend you check all drain hoses for kinks and clogs. If you clear the pump and the error returns, there's a good chance you will need to replace the pump. It doesn't take much to damage the small impeller. The pump may run, but it may not be pumping correctly. If you discover that you need a new pump, replacements can be found on line at searspartsdirect.com. Just type in your COMPLETE model number (located around the door opening) and look under the "Pump and Motor Parts" heading for (I believe) item number 10. This was the cheapest place I could find the pump. If you wish to check other sites, use the part number provided on the Sears website for your search.
I hope you find this information helpful and that it doesn't come to replacing parts. If it does, however, it's not a terrribly expensive repair if you perform this yourself. I can also provide you with step-by-step instructions on how to replace the pump, if necessary. Let me know if you have questions, and/or require additional assistance.
Sep 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
26 people viewed this question
fordexpert
Mike Squire
Robert Rankin
