System will not play thru tv. No sound. Radio and DVDs player work.
  • 28 Answers
SOURCE: Sony DAV SA30 dvd player
Hi From the symptoms, you mentioned, ie playing CD's ok., Mpeg decoder chip is faulty. The new one supplied is a modified type. IC207, part no.6-707-406-01. Good luck. Capital98
Posted on Feb 14, 2007
Doodad
  • 64 Answers
SOURCE: How to get sound through speakers with tv and not just dvds
Just wire your TV audio out to one of the receivers (DVD player) audio in and select AUX when you want the TV sound to play through the surround sound. You also might want to turn the volume down or off on your TV to get the full surround sound feeling, but that's your call.
Posted on Jan 06, 2008
  • 123 Answers
SOURCE: lx 9000r wont play any dvds even previously played
You can try reseting the unit.
Reset the set to the default factory settings:
All the information stored
(programmes, time and date) will be lost.
1.
Disconnect the set from power supply.
2. Press and hold down "STANDBY•ON" on the set and reconnect the set.
3. As soon as "IS TV ON?" is displayed, release "STANDBY•ON."
Hopefully reseting it will clear whatever problem it is having and allow you to once again use your DVD player.
Hope this helps. Good Luck.
Posted on Apr 08, 2008
SOURCE: Panasonic SA-HT680 DVD Home Theater Sound System
when i turn my home theater system on it says f61 then it shuts off can u plz help me out here =[
Posted on Oct 19, 2009
SOURCE: no sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
Posted on Dec 18, 2009
DAV-DZ777 no longer plays TV sound through home theatre. DVD, radio etc still works...
The hdmi needs to be ARC compatible and connected to the HDMI connected labled Arc.
Sep 10, 2016 | Sony Home Theater: DAV-DZ777 CODE FREE...
Why does disc tray open randomly Samsung ht-em54c
I had the problem of the disk tray opening and closing randomly but finally fixed it. I went thru a number of steps so I don't know which combination or individual step fixed it but I think it was changing the HDMI cable from the TV to the Blu ray player that finally fixed the problem. Previous to that I had removed the disk player and got the audio to work with only the TV and used one of the HDMI inputs as the output from my PC. That way I could play DVDs on my PC and run it thru the player to get audio in the speakers and video on the TV. Every once in a while the tray would try to eject (even though the player was not there). Finally I changed the HDMI cable to an older cable, the one between the TV and the player and it started working! I then put the disk player back in the unit and it all worked, everything!! Good luck!
Jul 22, 2014 | Samsung HT-X50 System
Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
Jan 22, 2009 | Sony DVP-CX985V Multi-disc DVD Player
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Unable to get play dvd or get picture on DVD channell on tv
If the player is doing that for all DVDs but playing CDs properly, the player has gone bad due to either the laser and lens being out of whack or the DVD drive just doesn't recognise DVDs anymore and needs repaired or replaced.
Sorry. Best of luck.
Jan 01, 2009 | Philips Televison & Video
Newer DVDs won't play properly
you need to buy a cheap av moulator (about 20.00 at most stores) this will solve the problem radio shack has them and so does wall=mart
Jan 13, 2008 | Panasonic Home Theater System System
Jan 06, 2008 | NexxTech ESDVD100 System
Phillips plasma tv - how to darken dislay while cable radio or music cd is playing?
The only thing you can do is unplug your video out lead from your dvd /cd player while playing it, also check your menu on your sony to see if it has a blank raster setting to activate. Second, why would you want to listen to a cd thru your tv, unless you don't have a stereo or surround sound system to play it on, of which I would definately have anyway. Hope this helps...
Dec 22, 2007 | Philips Magnavox 27MS343S 27" TV
LX3000D DVD Digital Surround System
the dvd player has a strip that comes from the lens to the board have that checked out by a yech probably it is broken or needs to be cleaned.
Mar 07, 2007 | Philips LX3000D System
23 people viewed this question
 Grubhead
Grubhead
